P 1208???
I got my car scanned at autozone and if i remeber clearly it was P1028. i threw 2 codes. It said coolant level Below Thermistat twice. The guy said i would need a new thermistat. and the other was a Cold ? Sensor. I dont remeber what its called. But i called Saturn and they want $280.00 for the thermistat installed and $75 for the sensor installed. Has any one had this problem?
Car runs fine, but coolant dosent get any higher than 135 Degrees.
wish i could help p1208 isn't in my manual, sorry, i see p1258 and thats an engine coolant over temp-fuel disabled, this is pretty self explanatory. It does sound like a temp sensor is messed up cause of the low coolant temp, but i'd make sure all fluids are filled in the reservoir tank and radiator just in case (i'm sure you've probably already done this).
$280 for a thermostat seems kind of expensive. Don't know how to help you there, i'd get another quote from another dealer to make sure they're not screwing you.
Hahaha o'ya you will run like **** when throwing a p0128 code, my car is throwing that code every damn day, my SES light doesnt go off and a cat effiency code and random misfire code i throw as well, my buddy said its doing this cause i have a bad thermo and its running rich from that or its cutting fuel off in the high rpms , then it clogged the cat and now my car runs alot slower then normal.....But im getting it fixed next week
