P0171 Lean code
P0171 Lean code
UPDATE:Ruled out the MAF calibration. It was tuned accurately by Fast98. Tried different tunes and same result. I'm throwing the P0171 at idle along with misfire in cylinder 1. I hooked up my interceptor and had 16 misfires in a matter of a couple of min in cylinder 1.
I have cleaned MAF and TB.
Tuned it back to Stage 2.
Reset fuel trims.
Checked to make sure hoses and sensors and couplers are connected.
I even tried turning off the feature on HPT that leans it out when decelrating.
Reset fuel trims.
I have the AEM dryflow and I checked it tonight and its not dirty. The maf settings have been tuned 3 seperate times. Once by Fast98, once set to stage 2, and once to a custom 42s tune. If anyone has specific MAF settings that could eliminate that PLEASE LMK.
Fuel trims need to be scanned and the results used as correction into your current MAF calibration.
Im using fast 98 tune and ive had no problems it was throwing that code a week ago and i adjusted the filter and its been gone ever since. I guess you checked all other conections vac lines and the boot to the tb
Ya I checked all the hoses and couplers. What gets me is that it is only at idle. Does anyone have good MAF settings for 42s and K&N Typhoon?
I know this may sound strang but when I bought my car new I would get 171 every other week. Finally at one of my visits to the dealer the mechanic took it apon himself to chase after that code again. turns out GM says its actually the airfiler that causes it. beingmisshaped or dirty causes the air to spirrel past the maf and a misread. I havent had a code for the last 4000miles and im stage 2. Hope this helps.
Fail Less.
ok... tuning the maf is more than just uploading someone elses settings. maf tuning is driving around and logging the maf error %. then copy and paste special (multiply by half) on your current maf table. do that until its dialed in to within + or - 3%.
heres another thought. did you fart with the PCV? alot of people try to throw a breather filter on the valve cover and block off the intake to avoid getting oil in the intake, this will throw a lean trim code.
would a bad maF cause it to throw a code only at idle??
sorry to threadjack dude but i'm having the same problem...but from what i understand is theirs either a lack of air in the cylinder or the injectors aren't able to compensate for putting in so little fuel...my thoughts are swap to a smaller pulley and maybe that will solve the problem, of course you're going to have to retune for the smaller pulley but does that make any sense to anyone else? Increase the amount of air the s/c is putting into the cylinders at idle so the injectors won't have to dump so little fuel in eliminating the random misfire?
Fail Less.
that makes no sense. if you are throwing a lean fuel trim code, why would you add MORE air to make the mixture leaner.
Smaller pulleys aren't the answer
Lean fuel trim means the computer is having to add more fuel because the o2 sensor reads a lack of fuel in the exhaust. If the ecu has to add more than a certain amt of fuel to correct the afr, it will trigger the code p0171.
Also another thing...he said it throws the code at an idle or somewhere near a stop...now if what someone else said is correct about the air spiraling past the maf then the air filter would most likely be the cause...but if that isn't it then I would have to say the fuel trims are a little jacked up. just because you tune it to put that amount of fuel to the car doesn't mean that the factory system won't recognize that as irregular... Flash have you tried flashing your pcm with the custom 42s tune you said you had?
