P0171 solutions
Old Aug 30, 2009 | 05:34 PM
94firebird's Avatar
P0171 solutions
my car has had the P0171 code for over a year....the dealership says its my STAGE 2 but they arent 100% what would be the best way for me to go about figureing it out....they want $1000 to fix it and the kit and instalation didnt even cost that much......so some insit with those of you who have delt with this would be great
Old Aug 30, 2009 | 06:16 PM
Sharkey's Avatar
do you have any other mods besides stage 2??? an aftermarket intake, or even the airbox mod can cause that code. check for vacuum leaks, make sure the clamps on your intake pipe are tight. basicly any leak you have after the mass airflow sensor could be the cause.
next question, did gm install your kit, and does your car still have factory powertrain warrenty (under 5 years 60k miles)??? if so, the gm stage 2 kit does not in any way void your warrenty if it was installed at a dealer, so they have to fix it under warrenty.
Old Aug 30, 2009 | 06:19 PM
Maven's Avatar
Theres a new reflash for the 05/06 STG2 cars, to cure random P0171s.
$1000 and they arent sure? thats odd.
blackngold20's Avatar
stage 2 has a warranty on it, doesn't it?
Old Aug 30, 2009 | 07:15 PM
Zach06CobaltSC's Avatar
It's probably your fuel trims out of whack. I would get the dealership to re-flash a newer stage 2 tune to your car and see if that cures the problem. If not, I HIGHLY recommend getting retuned by someone with hptuners. Dealership tunes suck and dropping a grand on something that may or may not fix it, is NOT worth it.
And yes, stage 2 is covered under warranty. Also this is something that should be covered under warranty. Either way, it's a quick and simple fix for someone with hptuners.
Old Aug 30, 2009 | 07:37 PM
Maven's Avatar
Old Aug 30, 2009 | 07:40 PM
haha maven that just made my night =D. I actually scrolled up to see if that's all that I said haha.
Old Aug 30, 2009 | 08:16 PM
94firebird's Avatar
ya i have no other mods and randomly the car will fix its self and the light will go away and run fine.....its still under warrenty but i guess the stage 2 is 12 mnths only and thats gone and they refuse to touch it.......
Old Aug 30, 2009 | 08:35 PM
Maven's Avatar
Yeah, since the stage 2 is an accesory it only gets 12/12 unless it was installed at time of vehicle purchase.
Old Aug 30, 2009 | 09:04 PM
94firebird's Avatar
ya those bastards make a part that works up until the warrenty expires
Old Sep 9, 2009 | 11:00 PM
94firebird's Avatar
how would i go about checking to see if i have a vacume leak?
Old Sep 10, 2009 | 01:57 PM
korbar22's Avatar
I had the same problem when i got my stg 2 kit installed... supercharger was torqued down to much
hope that helps
Old Jan 18, 2013 | 09:24 AM
turbosmart4's Avatar
I'm stock w p0171.... About to drive it off a cliff
Old Jan 18, 2013 | 10:43 AM
Hockeyman's Avatar
back from the dead!
Old Jan 18, 2013 | 01:56 PM
New zombie
Dustin24
47
Feb 12, 2016 04:10 PM
metroplex
Sep 27, 2015 07:48 AM
Cptnslo
Sep 24, 2015 09:32 AM
Dustonian131
Sep 23, 2015 08:03 PM
ashalle2
Sep 17, 2015 04:58 PM
