P1101 & p0103
Old Oct 14, 2009 | 12:29 PM
NexTnmE's Avatar
P1101 & p0103
The other day I did the boost bypass mod, and put a breather filter on the valve cover and a cap on the intake tubing where the vacuume line was. I got the P1101 code early in the morning when it was cold, doing just average highway driving.
I cleared it, and un-did the boost bypass mod, it was fine for two days. Then this morning I got P1101 & P0103.
Both times it has been 40 degrees or lower, and the only thing left I can think of is the breather filter... but that doesnt make much sense.
All the threads basically say to clean the MAF. I have the airbox mod with a K&N filter.
Any ideas?
Old Oct 14, 2009 | 12:31 PM
brickerenator's Avatar
Have you ever oiled your filter?
If so, that could be a source of the problem
If the filter isn't properly oiled, the MAF will get covered in it
Old Oct 14, 2009 | 12:37 PM
NexTnmE's Avatar
I have not oiled it... its probably only 8 months old... I wanted to get a Dryflow soon anyway... If I have time this weekend i'll clean the MAF and get a new filter...
Old Oct 14, 2009 | 12:40 PM
BLAZIN07SS's Avatar
I'm too JDM for you
any reason you decided to put a filter on the valve cover?
Old Oct 14, 2009 | 12:46 PM
NexTnmE's Avatar
Thought it would be a good idea to keep oily air from getting all over the throttle body...
Old Oct 14, 2009 | 12:56 PM
BLAZIN07SS's Avatar
I'm too JDM for you
except it needs vacuum to draw out those gases, re-install the line and put an oil catch can. search on here, some people have made some that cost like $5 to make at home depot
Old Nov 4, 2009 | 07:19 AM
NexTnmE's Avatar
P1101 still!
Over the weekend I put on a new AEM Dryflow filter (airbox modded), cleaned the MAF and throttle body, and put on the oil catch can. I have looked and there are no vacuum lines missing, not connected, or cracked.
Within 2 miles of driving on the highway in the morning (6:30am - about 39 degrees outside) I’m still getting P1101. After work I clear the code (4:00pm - about 50 degrees outside) and do not get the code. But the next morning I do again.
I really don’t know what else it could be help!
Old Nov 4, 2009 | 01:00 PM
Area47's Avatar
Rent me! per hour
shut it off.
Old Nov 4, 2009 | 02:49 PM
NexTnmE's Avatar
Originally Posted by Area47
shut it off.
I dont know what you're telling me to shut off... ?
Old Nov 4, 2009 | 02:53 PM
07LaserBlueSS's Avatar
The code can be disabled in HPTuners.
Old Nov 4, 2009 | 03:03 PM
NexTnmE's Avatar
Yes. But isnt there still and underlaying problem for the code to be activated?
Old Nov 6, 2009 | 12:00 PM
NexTnmE's Avatar
Yeeeeaaaaah... ummm... so... I finally just left the code alone, didnt clear it... and now it turned itself off... whatever man...
WopOnTour
Jan 22, 2015 02:08 PM
boostedgst97
Jul 30, 2013 01:15 AM
rukkee
Jul 9, 2010 05:55 PM
rukkee
Sep 21, 2009 06:47 PM
Xenozx
Jul 20, 2006 09:28 PM
