P1183 Code
P1183 Code
Hey all,
I am getting the P1183 code for the supercharger inlet pressure sensor the one on top of the SC. I bought a new one, and installed it, cleared the code but it keeps coming back. Any thoughts? No other codes just that. I recently had the SC, and the intake manifold off to replace the o-rings on the laminova cores as they were leaking, before i took it apart there was no code, only since i put it back together.
Thanks
Thanks
I pulled off the wire loom stuff, and found underneath a bunch of electrical tape, so i pulled that off and the 3 wires underneath all had a red crimp connector and the sensor wire had pulled out of it. So i cleaned it up, solder it back together and all is good. Thanks for the help guys. Now that is fixed. Now back to chasing the P0455 code (check gas cap), for that I have bought a new cap, fixed a few visible evap lines that had signs of rub on them (so possible holes). Going to get under the cars back end this weekend and look for more.
