p420
who is the converter made by.... most likely it is your cat! high flows dont last long before setting this code. this is what i did to solve mine if you dont have the money for a new tune go to autozone or wherever you like and buy a spark plug spark fowler that the sensor threads into. drill out the end so the o2 sensor threads all the way in and then put it in your down stream o2 and problem solved
el fin
