PCM Question? Maybe Possible to use Dashawk
No, it can't be done. If you somehow found one that has the same type of crank sensor, it wouldn't communicate with the other modules such as the power steering and BCM. Its the same reason nobody has run a stand alone engine management setup on a streetable car.
i think the costs of buying a new ecm, a dash hawk, and hptuners. or something to reprgram the ecm itself with the cobalt map is a bit extreme. there are other factors in the system. such as the CAN style itself. sure you can change the ecm, but the other costs and factors you have to add into it, just simply outweighs the original idea.
i know about the interceptors. But having dashawk molded in your dashboard i think would look better then a interceptor gauge anyday. Plus i think they look like ****.
Just trying to make something new for my ride. Thats all. Money's no problem.
Last edited by Freakenhye; Aug 16, 2007 at 12:17 PM. Reason: Automerged Doublepost
You would also be looking at the cost of a few grand just to buy a standalone, wiring harness and everything else you would need, which probably wouldn't work with a Dashhawk anyways not to mention what this would all cost in labor and tuning.
Ok, the reason the Dashhawk won't work is because of the protocol used by the PCM to communicate with other modules on the car's network. If you do anything to alter this setup, you will lose at least power steering, air bags, gauge clusters, ABS and other features I'm probably fogetting.
Why cant we start with the 2.4 ss ecm. Its basicly the same car just the supercharger.
While you're at it, swap in a computer that is capable of controlling the toaster oven that will be in your glove box so you can cook up some dope ass grilled cheese samiches while you're running 10s in the 1/4 mile.
If they said the same thing to whoever invented something then your ass wouldnt have a car.
grilled cheese for the effin win!
if you want to watch what your car is doing. you can spend the money for two interceptors. or get hpt and a fancy laptop.
the 2.4 and 2.0 are TWO DIFFERENT CARS
the signals from the sensors are different, the crank sensor is different. the ecm, and wiring, and sensors are different, they are read different, and this in a nutshell. will not work.
to be nice, all this work is pointless. by the time you get this to work right, is the time i stick a blow through turbo/carb setup on my car.
