PCM Under cover
PCM Under cover
I plan on getting gm stage 2 in a month or two and I hate that the rev limiter is droped to 6500 instead of 7000 which is not the case for everyone but i can be one of the unlucky. Now the real question is can I adjust the rev limiter to 7000 with out my warranty being voided? ZZP states that their tuned pcm cant be detected by gm and will keep it's warranty. I need some insight because this 6500 rpm is bugging me!
there pcm cant be detected because it is another pcm, not your original one. So if you went in for warranty, you just switch out your ecu.
No, the dealers can tell if a pcm has been flashed. If they decided to take a look, they will noticed and void warrenty.
I got it for 6 years just got the car a year ago. I plan on having it at least 2 years 3 at most.
I was going to void it but when I snaped my axle i was happy I had it.
true..
i thought maybe you were close to having to lose it anyway...
when i got my car i didnt have a warranty... so i was like what ever... lol
I would keep it for a little while longer too.
Read around a little about this some get 6500 some 7000 on the newer flashes. It's wierd and fucked up!!!
I will find a way.
I will find a way.
No sir, new flashes are not.
I thought the same thing as well, and had the same reaction you did..
Promise.
its all going to be the same with this much time past...
Last edited by ShortStack; Mar 18, 2009 at 01:20 AM. Reason: Automerged Doublepost
it will only be your powertrain warranty! Remember, your tune still has nothing to do with your brakes, interior, body, ECT.
The law states: Effected part has to be caused by questionable part, ie: tune.
So if your door falls off, they can't deny your warranty because of the tune!
