People with widebands...
Old Mar 21, 2007 | 01:17 AM
dervin3's Avatar
When you are cruising around or idling whats your display say? I have the AEM UEGO and while cruising or idleing the "needle" and display bounce anywhere from 14.5-16.0
Is this normal? When I go WOT though its easy to read and doesn't bounce at all and steadily lowers down to just about 10 flat lol...I know I know I'm gonna get that taken care of very shortly
Old Mar 21, 2007 | 01:25 AM
Johnboy12358's Avatar
Yeah, I was at the dyno today and mine would get up like that when the engine wasnt under load, I think you're safe
Old Mar 21, 2007 | 01:38 AM
XenSS06's Avatar
Not to thread jack but i got a quick question about this subject also.
do we have to weld a bung in our down pipe to install a wide band because i want one but i need to no if we can just hook it up or i need to mod my pipes.
Thanks
Again sorry about the Thread Jacking.
Old Mar 21, 2007 | 01:43 AM
dervin3's Avatar
Yes a bung has to be welded into the downpipe (before the cat) and one is supplied with the UEGO
Old Mar 21, 2007 | 01:47 AM
XenSS06's Avatar
about how much on average to do that?
dervin3's Avatar
I got it done for 15 bucks
Old Mar 21, 2007 | 01:51 AM
XenSS06's Avatar
Cool thanks for the info
Old Mar 21, 2007 | 07:45 AM
blown06's Avatar
I was wondering the same thing at idle my sits around 15.3 bouncing around. So I am too nervous to take it out until I can get a tune done. The only thing I have done is add a dp and ported the blower, and before that I was running pig rich, I know you need to tune after porting the blower.... but I didnt think I would be that off......
Old Mar 21, 2007 | 10:08 AM
silverSS's Avatar
did you install it at the 12 o clock position on the dp?
did they have to remove the dp to install it?
Old Mar 21, 2007 | 10:25 AM
Doc's Avatar
Doc
install it anywhere from 9 o'clock to 3 o'clock....
it might be easier to remove it although it can be done while on the car too
Old Mar 21, 2007 | 10:41 AM
dervin3's Avatar
mines installed at like the 4 oclock position and he didn't take it out to do it. Also that's looking at it from under the hood.
Old Mar 21, 2007 | 11:02 AM
blown06's Avatar
mines between 9 and 10
Old Mar 21, 2007 | 01:40 PM
bc3tech's Avatar
9& 3 on the top end not 4,5,6,7 or 8
Old Mar 21, 2007 | 01:46 PM
dervin3's Avatar
May I ask whats wrong with the bottom? Just asking because thats how the mechanic did it. Hell he's been around here for a long time so I assumed he'd know how to install a o2 sensor.
Old Mar 21, 2007 | 01:48 PM
Doc's Avatar
Doc
water condensates at the lowest point....meaning, your sensor is more apt to getting water on it the lower it is. Believe it or not, the exhaust contains water, not a lot, but enough to skew sensitive parts like a O2 sensor.
Old Mar 21, 2007 | 01:54 PM
dervin3's Avatar
Oh ok, well like I've said before during WOT it's really accurate and steady. It's just when I'm idling and cruising is when it bounces around and even after it's warmed up it still does it. I was following behind a eclipse with the same gauge and his was doing the same thing while we was stopped at the light.
Old Mar 21, 2007 | 02:13 PM
Doc's Avatar
Doc
its the CA gauge pod thingy thats the culprit
Old Mar 21, 2007 | 02:17 PM
Youlikadasauce's Avatar
I just installed mine recently and this is what it reads. Steady driving (55ish) it reads between 14-16. When gassing it, it reads around 11.3-13.5. When starting the car it reads 13.3 then jumps to 15 once the car warms up. At idle mine is everywhere as well. I can tell it follows the car really well, between high and low idling it shifts acordingly. So yours sounds right, I asked the same thing when i installed mine .
Old Mar 22, 2007 | 05:29 PM
Boost Fr33k's Avatar
yeah but only when intially starting the engine. doesnt condensate all the time but to be safe dont put it on the buttom.
Old Mar 22, 2007 | 06:48 PM
CobaltPerformanceParts's Avatar
The bouncing you see at idle and cruising are normal. That is the way stock computer is set and it saves fuel at low load and steady rpms. Such as highways cruising. Nothing to worry about. The change in start up air to fuel is due to the warm up procedure.
Old Mar 22, 2007 | 08:56 PM
AdamRedSS's Avatar
in my c-a catless downpipe there is a thread in it for the factory o2 sensor. the uego has no thread? we just put it in that hole and weld it? btw my rear o2 is disabled so it will be alright to just take the factory one out.
Old Mar 22, 2007 | 09:40 PM
blown06's Avatar
so at cruising it should read 14-15 and under WOT it should be 11-12? Sorry guys I am starting to learn the whole tunning process now lol..... ideal should be around 11-12 correct
Old Mar 22, 2007 | 10:36 PM
davytudope's Avatar
at wot i would have a/f ratio at about 12.2 to 11.8
but thats just me
Old Mar 23, 2007 | 12:04 AM
take a look at my dyno sheet (theres a link in my sig, click my whp and wtq numbers)
Alot of people have told me that this is a really good AFR to have (i must be lucky or something)
WOT @ 6000+ I got down to 11's and I think thats where you are supposed to be
Old Mar 23, 2007 | 12:12 AM
dervin3's Avatar
that looks to be 11.5-11.7 Somewhere around there. I'm by no means an expert but I'd be really happy with the A/F ratio also.
