Petrol
But then again... someone would have probably asked... lol..
its kind of a given when someone says "highest you can get" that they mean, highest you can get out of regular octane grades at the pump. 87-89-91-93
Alright thanks guys, I was running 93 but just wanted to check. Now does anyone have any ideas what may cause my car to have check engine light on with codes P0068 and P0069? Kinda happened out of the blue, wasn't even running it hard.
P0068 Throttle Body Airflow Performance ECM, PCM
P0069 Manifold Absolute Pressure - Barometric Pressure Correlation PCM
Almost sounds like your throttle body might be on the fritz, or maybe just the butterfly is sticking. Were you doing normal driving when it happened, at idle, or at WOT?
Ya I was thinking throttle body too. It was just replaced and that could have something to do with it. Anyway I was making a U-turn and gave it about half gas enough got up to about 8lbs of boost and just went limp on me. I shut it off, she ran decent except for idle on the way home. CEL was still on. I gave it some gas a bit later after driving, it stuttered at 10lbs of boost then went limp again. . . .
Thats when I read the codes, wrote em down, and deleted em with the OBDII reader. CEL is off now but I think the problem still exists. Havent gotten into boost since then. . . so it might be gone but I doubt it
Thoughts?
Thoughts?
Thoughts?
Thoughts?
sorry for the thread jack...
Not a problem
I have the stock intake, only upgrade is the GM stage 2. Turns out, after erasing the codes, unplugging and replugging in some wiring harness stuff, the car is running fine. I drove her around and without any problems, even peaked at 15psi.
Also I used to live in Coral Springs ahaha
Not a problem
