pics of plugging supercharger holes
Old Mar 24, 2008 | 03:12 AM
hungryhip-ccp's Avatar
Originally Posted by sscobaltscZ06
Some people would put a tuna sandwich under their hood if they heard someone else did it for more hp.
lol your a funny guy... thanks for sharing, actually i did see a increase in boost by nearly 2psi and on scanforce saw a 7hp gain... now that could be anything like temp and humidity but i think the increase in boost tells the story... and thats 7 flywheel hp not whp
Old Mar 24, 2008 | 03:19 AM
3fo893013L's Avatar
Old Mar 24, 2008 | 03:50 AM
Originally Posted by Mnatvyc1223
direct quote frm the sticky Ralli:
Air Leakage Ports:
The two oval slots on the output plate are air leakage ports. Their only purpose is to decrease operational noise from the blower. Arnie, from Eaton Corp., explains their function like this, "When you stomp on the gas, the boost shoots up and the air flow goes supersonic. The air then slams back into the output plate and through the leakage slots, which reduces the hammering of the air into the housing causing less noise. The OEM can not have such loud NVH, that’s why we put them in the housing. The 2 small ports are not there to feed air, only to reduce noise." Basically, for the best flow and most efficiency, these ports can be blocked off, making the outlet port (triangle slot) the only port on the outlet plate of the housing. Closing these ports will not increase IAT's; however, it will make the supercharger much louder when in boost. As an example, aftermarket supercharger companies, such as Harrop, Roush and Magnuson do not use these slots in their blowers. It should be re-stated, that you should consult professionals regarding closing these ports; and do not, for any reason, plug them with JB Weld. Improper closure could eventually lead to pieces coming apart and loose debris destroying the rotors and housing. Opening up these ports will only have a negative effect on efficiency. Do not port them.
heres the thread...
https://www.cobaltss.net/forums/show...silencer+holes
now please take a
Enjoy!
that was ****** awesome couldent of done it better i will
i dunno, maybe the info they received was wrong- thats y i always try and source the engineering info.
oh well- i dunno if i would try this... too risky
whats so risky the **** cant go in the motor even if i did fall out it cant make it past the laminova (dont know the spelling) cores and you make em big and heavy so even if it fell (which i highly doubt the grand am guys have been doing this for years) there wouldent be enough vaccum in the engine to even pick them up off the intake manifold bottom
Last edited by hungryhip-ccp; Mar 24, 2008 at 03:50 AM. Reason: Automerged Doublepost
Old Mar 24, 2008 | 09:46 AM
XCRuna1201's Avatar
Originally Posted by INDColtsFan18
i have a feeling those holes were put there for a reason. I doubt they would take the time to drill 2 holes in a supercharger, if they were pointless. I would not recomend doing this, unless you don't care about your warrenty, or you want to take the rise of blowing your SC.
If you would read the thread which is the link in the first post...the companies who make the superchargers for cars like this have to put those in because of *noise violation*. If they didnt have the wholes it would not pass db level tests.
Old Mar 24, 2008 | 09:50 AM
Rodimus_Prime's Avatar
unless its providing more power i dont see the point
Old Mar 24, 2008 | 09:55 AM
Maxim_X's Avatar
The two oval slots on the output plate are air leakage ports. Their only purpose is to decrease operational noise from the blower. Arnie, from Eaton Corp., explains their function like this, "When you stomp on the gas, the boost shoots up and the air flow goes supersonic. The air then slams back into the output plate and through the leakage slots, which reduces the hammering of the air into the housing causing less noise. The OEM can not have such loud NVH, that’s why we put them in the housing. The 2 small ports are not there to feed air, only to reduce noise." Basically, for the best flow and most efficiency, these ports can be blocked off, making the outlet port (triangle slot) the only port on the outlet plate of the housing. Closing these ports will not increase IAT's;however, it will make the supercharger much louder when in boost. As an example, aftermarket supercharger companies, such as Harrop, Roush and Magnuson do not use these slots in their blowers. It should be re-stated, that you should consult professionals regarding closing these ports; and do not, for any reason, plug them with JB Weld. Improper closure could eventually lead to pieces coming apart and loose debris destroying the rotors and housing. Opening up these ports will only have a negative effect on efficiency. Do not port them.
LoL I guess if it's not called jbweld....
Old Mar 24, 2008 | 10:04 AM
lsjwannabe's Avatar
my blower from harrop isn't that loud
Old Mar 24, 2008 | 10:05 AM
BRN169's Avatar
Humm...
"...do not, for any reason, plug them with JB Weld"
Never mind...
Old Mar 24, 2008 | 10:06 AM
Drakonen2000's Avatar
Originally Posted by BRN169
Humm...
Never mind...
that quicksteel stuff isnt anything like jb weld.....its fine
Old Mar 24, 2008 | 10:20 AM
Joeyavhu's Avatar
How hard is the install and how much extra power? I might be into trying this....
  #36
the trick is getting it under the hood without eating it first...it might take a couple trys, but its good for atleast 90 WHP!
Old Mar 24, 2008 | 10:21 AM
  #37
lsjwannabe's Avatar
no power just a sound, kind of like a intake
Old Mar 24, 2008 | 10:23 AM
  #38
Joeyavhu's Avatar
No... I was talking about the Tuna Sandwich mod. Lol
Old Mar 24, 2008 | 10:27 AM
  #39
Kibosh3's Avatar
i did this once...needed a new blower after that...may or may not have been the reason...
Old Mar 24, 2008 | 10:39 AM
  #40
SSSCEnthusiast's Avatar
It doesnt sound any louder than my Injen, IMO.
Old Mar 24, 2008 | 10:43 AM
  #41
Rangerondubz's Avatar
Originally Posted by ralliartist
Well, that is good info to know, I'm just wondering why stiegemier says that you'll lose power cause of heat if you block those holes off.
I called them a few months ago when this was going around and they told me differently. Ever wonder why the TS and TVS dont come with the ports?
Old Mar 24, 2008 | 11:27 AM
  #42
Area47's Avatar
Rent me! per hour
well. hmmmmmmm okie dokie
Old Mar 24, 2008 | 02:56 PM
  #43
Wise man once say
Adding Noise not make more power, Adding power makes more noise
Old Mar 24, 2008 | 03:02 PM
  #44
M-Dub's Avatar
So those that have joined the ranks of the sneeze mod on SRT4s.... COOL!
More noise no more powa! Well I guess if that is what you want... but my 2.80 stock blower is MUCH louder than that!
Old Mar 24, 2008 | 03:09 PM
  #45
dude it took 5 min but i let it cure for 12hrs
wait till i drop the 2.8 and make another video tonight
Last edited by hungryhip-ccp; Mar 24, 2008 at 03:09 PM. Reason: Automerged Doublepost
Old Mar 24, 2008 | 03:11 PM
  #46
Kibosh3's Avatar
ya...it was fine until i dropped it to 2.85...then the rotors started acting up....
Old Mar 24, 2008 | 03:16 PM
  #47
Omega_5's Avatar
OMFG.... another 'plug the ports' thread....
Why do people continue to think that boost = power?
Old Mar 24, 2008 | 03:20 PM
  #48
BlilBT's Avatar
Well I would have to atleast put it under the hood to toast it alittle thats good for 1 HP! Get it HP (Human Power)
Old Mar 24, 2008 | 03:29 PM
  #49
originaladrian's Avatar
tht made me lol
Old Mar 24, 2008 | 03:30 PM
  #50
hydraze's Avatar
...this is the most pointless, useless, powerless mod you can ever do to the s/c! not to mention very risky, what if, just what if that putty comes off. u know where its going.
