Please help
Old Aug 20, 2010 | 11:29 PM
jmo2010's Avatar
Please help
Ok so maybe a week ago i put in my new zzp s3 intercooler and I did the airbox mod. Well anyways I was driving home in the middle of a thunderstorm after i drove over an hour then ate somewhere and maybe 30 to 45 min headed home, well I turned on my ac/defrost so I could see in the storm and I very quickly around this time started to smell something as if it was burning rubber or burnt hair just that nasty burnt smell.... So I immediatley thought it was subs and stuff in the trunk, and this seemed wheret he smell is the strongest...possibly idk for sure but i also turned the rear defrost on when I majorly started smelling it... I also just painted my tailights yesterday and used a reverse light off of an old trunk that I used for practice but anyways I just didn't want to leave out any details. My coolant seemd alright and subs sounded like they were working fine and I just drove the same amount of distance 2 days ago and everything was fine but I didn't do anything with the tailights yet. I actually think it might becoming from them, Idk I'm freaking out because I spent way to much on my subs for something to go wrong but they are hitting fine and I took them out and they seem to be wired correctly...
but i'm goiing insane! please help!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old Aug 20, 2010 | 11:37 PM
donkeyballs's Avatar
How loud are you turning it up when you smell it ? It could be the coils getting hot ..
Old Aug 21, 2010 | 12:01 AM
jmo2010's Avatar
loud but not freakishly loud, I have two Memphis M3s 12 inch 500 rms a peice, powered by a 700 watt JL mono amp...They are fairly new too...maybe a couple months old..I didn't think they would be heating up if they were each a 1000 peak... and there m3s so they should have pretty true wattage idk.
Old Aug 21, 2010 | 12:12 AM
jmo2010's Avatar
I do have it on +15db and level 12 bass boost which is as high as it can go on both of em...idk its freakin me out kuz all together i spent 1200 on my sound system and im scared something in screwed up...but nothing sounds distorted or bad or anything....
Old Aug 21, 2010 | 03:06 AM
06SuperSportChevy's Avatar
If there still new they will smell like that if you pound them. My two 12" type r's still do it If I crank them up for a bit. I had them for a while but don't use them that much. so It's normal if it is the subs and should go away eventually.
Or just adjust them a bit to not hit as hard.
Old Aug 21, 2010 | 10:06 AM
jmo2010's Avatar
alright, ya I was planning on adjusting them. They have smelt like new for a lil bit but this is a burning smell. Like a lot different lol.
Old Aug 21, 2010 | 10:59 AM
Well then... I can't see it being the taillights, I painted mine without a single problem.
Maybe it's the cat. I know they start to stink real bad lol.
Old Aug 21, 2010 | 12:55 PM
jmo2010's Avatar
ahh well i heard that to i fogot about that! but wouldn't my exhaust sound like crap? it didn't come until i turned on my defroster/ac and i know there is a recall on them...
Old Aug 21, 2010 | 09:58 PM
Its your subs.. What kind of box are they in ? Just be careful you can burn the voice coil out and it will smoke and really stink.. your prob pushing them a little to hard just bring the gain down some..
Old Aug 23, 2010 | 01:58 AM
jmo2010's Avatar
Ya I found out its my subs. I asked the audio store that I bought em from and they told me that I should turn my amp to 80 hrz and turn the gain to 80%.. Its a custom box that they built. and its sealed.
