Poly control arm bushings...
I had a few questions about these, but figured they are pretty much required since I am going Stage 2 with I/H/E. I see I can purchase them from jbodyperformance.com and see both them and many people here have noticed they almost completely eliminate wheelhop. This is what I want but had a few questions before I purchased them.
1.) Where can they be installed at? Should I have my dealer do it, and what would something like this cost for instalation?
2.) Is it a difficult instalation and can it be done wrong or have any negative side effects? (bad ruff idle? Etc.)
3.) What about your warranty? Would this void warrantly on any parts? I Know that your warranties not void unless the part installed caused the problem. Whats the potential of this type of part causing any issues?
4.) Anything else I should know?
You can also order them from Intense. http://www.intense-racing.com/Mercha...LSJ_Suspension
It will be cheaper and you'll get them faster becuase they won't have to be shipped from Canada.
Sweet, thanks for the info. I begrudged my dealer because of my intake, but I figure I will give them one more chance. I think Ill do stage 2 and these bushings at the same time maybe a month from now.
I get stage 1 installed next week, and I will also have my summer tires put back on as well as an oil change. Then Ill wait for my next check to do the bushings / stage 2.
Thanks for all the info peoples, appriciated.
On a side note, my dealer quoted $300 total to install stage 2, ZZP motor mount, front transmission mount, and the bushings. A small shop I found around here wants $89 for the motor mount, $179 for the front transmission mount, and $129 per bushing for a grand total of $526 + tax
Originally Posted by mken
Now you tell me! I ordered from JBP on the 3rd and the estimated delivery date is the 12th! According to their online tracker, the last event was the acceptance of the package for delivery on the 4th...
(stage 2 install not included, I'd still get the dealer to do that for warranty purposes). Never thought the best price would come from a dealer...
The bushings, do you get any hard vibrations while idling? I heard something goes that but I dont know if it was bushings or the tranny mount.
How hard would it be for someone who can install an intake to install an engine mount? Equal or more difficult?
Is it motor MOUNTS or MOUNT that is being replaced. I figured thre was a main mount or something and all the other mounts would hold it in place while you change the one. I guess this is wrong, you need to support the egine or risk it falling?
You will most definitely notice vibrations. Before I had to look at the tach to see if the car was on (not really but it is quiet with the windows up and stock exhaust) Now you know without question. Vibration can be felt in the steering wheel and in the seat. It isn't really bad though, I consider it a fair trade-off. I think it is more the tranny mount than the control arm bushings.
Originally Posted by astrocrep
Can you dump the clutch??? Even sub 2k rpm w/out wheel hop?
Thanks
-Rich
Thanks
-Rich
Since the weather has warmed up slightly (low 50s) I haven't even gotten the two small hops out of it. Nothing but spin
Originally Posted by ballerSS
I have only the control arm bushings done and I did a full out launch, got two small hops and then nothing but spin. I was on the stock rubber and it was 35 degrees out. On the exact same road and spot I tried racing a GTI last fall (about 45 degrees) and I looked like a damn fool because I didn't go anywhere, just sat there hopping like a maniac. Stupidly I tried to 'gas it through' as you can guess that didn't help. LUCKILY I didn't break anything.
Exactly what happened to me. I tried to do a burnout, got to small, quick hops then rubber.
It was a bit chilly out for me as well. Walk the clutch out just a tad and there is no hop.
