Possible Throw out bearing? Doesn't move..
Old Jun 13, 2011 | 01:47 AM
Tstonee's Avatar
Exclamation Possible Throw out bearing? Doesn't move..
I went to dump my clutch today.. and nothing happened..
Now........................
I can go into gears w/o the clutch, and get out of gears w/o the clutch
I can put it into first gear, get off the clutch, and it doesn't stall
My driveway is a sliiight hill.. Like if you don't use your e-brake then you'll slowly roll back.. I was rolling down it and would put it into first, and it would barely catch and be able to stop me from rolling back, but wouldn't be able to pull me back up the hill (even w/ gas)
Here's a pic of _______.. but It should help you, help me
Oh, and when my buddy moved this, it moved my shift knob back and forth, and one time when he was moving it, he put it into 3rd..
One person told me it could be a trans issue, he's not 100% sure... and another told me throwout bearing...
&&&&&&&&&&&&&&& I just had the clutch replaced a month or two ago.. idk if they replaced throw out bearing.. i'll have to find out tomorrowwww.
More pictures from further away...
And a nice shitty video to see WHERE exactly the main picture is...
Old Jun 13, 2011 | 02:03 AM
SlowCobaltSS's Avatar
WTF is that
Old Jun 13, 2011 | 02:05 AM
Tstonee's Avatar
Exactly why I posted the picture... /:
Old Jun 13, 2011 | 02:14 AM
What angle did you take that picture from I just went out and looked at my car and I dont even see what you took the picture of
Old Jun 13, 2011 | 02:15 AM
jschru's Avatar
try to get a picture a little further out so we can get an idea of where were even looking in your engine compartment.
Old Jun 13, 2011 | 02:17 AM
Tstonee's Avatar
Hmm... driver side.. You'll wanna be right behind front wheel.. My buddy actually took the picture.. I never even went down there /:
******* christ.... my friend took it while the car was jacked up.. i'll go out there now and see if I can get anything.. brb /:
Old Jun 13, 2011 | 02:19 AM
Ok well I didnt go under the car I just opened the hood and looked around
Old Jun 13, 2011 | 02:26 AM
Tstonee's Avatar
Yeah you're gonna have to lay down /;
It's by the clutch/trans/all the good ****
Old Jun 13, 2011 | 02:33 AM
Tstonee's Avatar
Might this help? Quality sucks ****.. but I just wanted you to get the general idea of where it was..
Old Jun 13, 2011 | 11:04 AM
Tstonee's Avatar
Help!
Old Jun 13, 2011 | 01:41 PM
Tstonee's Avatar
Helppppppppppp
Old Jun 13, 2011 | 08:53 PM
D_Rob's Avatar
If that fluid is oil from in your transmission or transmission case, it is most definitely more that a throw out bearing. Throw out bearings typically give you issues getting it into gear (you push the pedal, nothing happens or pedal doesn't push), also having issues getting it in gear could be a pressure plate. If your throw out bearing was stuck in the engaged position this might be possible, though the symptoms don't match, your pedal would be at the floor and not returning back up, and I have never heard of the bearing being stuck in the engaged position.
Unfortunately, It would appear you have at best, sheared the disc or had a spring in the pressure plate come out (I have done this on Honda's) or at worst (grits teeth/this is what I think) broken your transmission. In which case neither will be known without that thing coming back out of the car. Throw out bearings are the easiest part of a clutch job, so it's less likely that they did not replace it when they did your clutch. Sorry man, and good luck.
Old Jun 13, 2011 | 10:19 PM
Tstonee's Avatar
Well my car is in the shop (Jay's Racing) right now.. and being looked at... Jay took a real quick look at it, just from going under it and he said it looks like it has something to do w/ the axles... but he was gonna lift it tomorrow and lemme know more.
06MetallicBalt
Jul 20, 2025 08:47 PM
RaginChopsuey
Oct 27, 2015 01:27 PM
HEATON
Oct 16, 2015 07:21 PM
DANRICKARD
Oct 1, 2015 12:08 AM
OPCrer
Sep 27, 2015 08:11 PM
