power question
Old Sep 14, 2007 | 03:59 PM
stotte20's Avatar
power question
ok here is my question. i have heard a lot of things about the stock motor only being good for 300hp because the pistons will not hold any more then that? and i have also heard that 300hp can not be achived with out bulding the motor or swaping out the supercharger for bigger one or turbo? i really would like to know this because as of now i have full exhaust gm stage 2 with 2.79 pulley k&n cold air. and i want to add after cooler get 60# injectors with meth 2.5 pulley and dual pass intercooler plate. and get it all tunned. at this point should i be worried about frying a piston or having somting go wrong. or should i just go ahead and plan on building the motor? thanks for your help guys
Old Sep 14, 2007 | 04:17 PM
RaineMan's Avatar
You're gonna be making a lot of heat with that much boost out of the M62.
It's not the fact that the engine can't take the power... it just can't take the heat... there's a subtle difference. The M62 is just a big heat pump at high boost levels. The serious guys on here talk about swapping to a twin-screw or turbo b/c it makes less heat.
Old Sep 14, 2007 | 04:26 PM
SSalexSS's Avatar
do they even have the twin screw out for sale?
Old Sep 14, 2007 | 04:31 PM
RaineMan's Avatar
not yet... give it time to get finalized... they've proven that it works... just needs fine tuning.
Old Sep 14, 2007 | 04:37 PM
SSalexSS's Avatar
mmm i see would our engines be able to even handle it since stock it only holds wat 310 hp?
Old Sep 14, 2007 | 04:46 PM
RaineMan's Avatar
handle it?
You can change the pulley size on the twin-screw to make as much or as little boost as you want to... the SC dosen't make HP without the pulley.
Old Sep 14, 2007 | 04:57 PM
Area47's Avatar
Rent me! per hour
300 to the tire.
300 to the crank.
big difference.
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
brandon04
Oct 21, 2015 07:04 AM
Stuff
Oct 1, 2015 05:47 PM
Extremespeed
Sep 29, 2015 04:34 AM
Iceberg
Sep 28, 2015 01:31 PM
