Problem at high rpms. Sputter?
Old May 11, 2009 | 04:21 PM
flash13brandon's Avatar
Yesterday, floored it in 2nd and at around 5500 rpms, the car acted up. I guess you could say it sputtered? Hesitated for a second. definitely noticeable. A friend that was with me said it felt like it hit fuel cut lol. Stepped on it again like 5 min later and it ran like a champ so i kinda shrugged it off. But then today it did it again at 5-6k rpms in 1st gear. Sounded like a "pop" today when it did it. I'm running one step colder plugs gapped at like .035...never had any problems like this before. Haven't changed anything lately on the car. No check engine lights either.
Old May 11, 2009 | 04:24 PM
Bika's Avatar
Fail Less.
either tune related knock, or spark blowout
Whos tune you have?
Old May 11, 2009 | 04:26 PM
BEASTmode632's Avatar
does it do it in every gear? or just first?
Old May 11, 2009 | 04:33 PM
beamer1341's Avatar
mine did this the other day in third hard accel on the on ramp after about 4k kinda bucked alittle i put some fuel treatment in it (lucas FTW) seems to be fine now
Whos tune you have?
I've been running the same tune for a couple months. Tuned by Josh at OTTP.
It has done it in first and second so far.
Old May 11, 2009 | 04:36 PM
Bika's Avatar
Fail Less.
It's a common occurrence. Not a huge deal unless it happens frequently.
If you have access to HPTuners, do a log and post it.
Old May 11, 2009 | 04:40 PM
Why is it a common occurrence? I've never had the problem before. Do you know what causes it?
Old May 11, 2009 | 05:13 PM
Zach06CobaltSC's Avatar
It's a common problem but its not normal. Are you seeing an increase in boost by any chance? That would lead me to believe it could be a clogged cat. If there isn't an increase in boost then start off by changing your spark plugs and gapping them at .035. Make sure there the ngk bkr7e's. Also run a couple bottles of heet through your gas tank and run the gas as empty as you can and refill up at a new station with 93 octane. Make sure its not bad gas and not bad plugs. After that try the fuel filter and air filter.
Old May 11, 2009 | 05:18 PM
ecotecon18s's Avatar
Mine started doing it again after I put the stock airbox on...try cleaning the air filter and MAF...
Old May 11, 2009 | 07:10 PM
baltimorebalt's Avatar
mine did same thing in 3rd now and then, I checked plugs ...one was a little off regapped it plus checked my cai which was wet as hell (had a freakin ecosystem growing on it haha) got a replacement filter and im good now. Had cel for random misfire in there too but not sure if they related at all. Anyway hope this helps bro gl
Old May 11, 2009 | 07:21 PM
Bika's Avatar
Fail Less.
unless your plugs are fouled or your air filter looks like ****, I'm going to say its just a case of a lil knock.
Old May 11, 2009 | 08:44 PM
rukkee's Avatar
Alot of Gm tuned car's have this , mine has done it 3 or 4 times in the last 3 years.
Old May 11, 2009 | 08:48 PM
BLAZIN07SS's Avatar
I'm too JDM for you
mine has done this a few times. only when the plugs were older though. i swapped them out and it stopped. i blamed it on spark blowout
Old May 11, 2009 | 09:12 PM
HOT CARLS SS's Avatar
Re- gap your plugs smaller ...will fix the problem...
Old May 11, 2009 | 09:18 PM
Bad05SS's Avatar
sounds like it might be running to lean, so the motor it starving at higher rpm. mine dose the same thing and i have no tune all stock my maf is bad so it runs alittle lean
Old May 11, 2009 | 09:59 PM
I'm going to pick up a new set of plugs and see if that could be it, but they are only a few months old. Running rich can cause the plugs to foul correct? Because I'm seeing mid 10s for AFR. Maf calibration is off I believe and it's causing it to run rich.
Old May 11, 2009 | 11:47 PM
Bika's Avatar
Fail Less.
since you have new, colder plugs, gapped at .035, and you are in the mid 10s AFR u probly just had a quick spark blow out. It's rich, but not plug fouling rich.
no_ss
Oct 18, 2015 11:58 PM
Slick_Nick
Sep 28, 2015 09:15 PM
DocSvensk
Sep 27, 2015 02:24 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
Dirtybutwhole
Sep 26, 2015 03:29 PM
