Problem with ZZP dual-pass endplate
Old Nov 8, 2021 | 01:31 AM
Smc252's Avatar
ZZP dual-pass endplate seems to not seal correctly. Looking at the brand new stock one, they have different shapes where the o-rings sit.
Does anyone know where to get the big o-ring that goes between the manifold and plate?
Old Nov 9, 2021 | 12:09 AM
Smc830's Avatar
I put the stock end plate back on and apparently the leak is on the inside of the manifold, opposite of the end plate.
Old Nov 9, 2021 | 09:53 AM
USMCFieldMP's Avatar
Rattlesnake Race Shop
Did you pull your cores and flip them around when you installed the dual pass end plate? And did you do the same when installing the stock end plate?
Old Nov 11, 2021 | 04:01 PM
Smc252's Avatar
I didn't flip them, they're stuck. My end plate is perfectly level too. The leak is on the backside of the cores. I am now using the manifold without water and plugged both hokes. I must use water injection or chop up the manifold. (Or replace it)
Old Nov 11, 2021 | 04:19 PM
Then dual pass isn't going to really help. Did you attempt to flip them and potentially damage a seal on the side away from the endplate?
Old Nov 11, 2021 | 05:23 PM
Yeah, two cores absolutely have to be flipped for the dual pass to work... otherwise the system is a dead-end. Meth is a band-aid that isn't big enough to cover the lack of an intercooler.
https://s3.amazonaws.com/zzpstorage/...s+Kit+revA.pdf
Pay attention to Step 4: https://www.cobaltss.net/forums/how-...rnator-274630/
Testing your cores for leaks; post 13: https://www.cobaltss.net/forums/prob...nstall-323316/
Old Nov 18, 2021 | 09:10 PM
Smc252's Avatar
I found a saturn ion at the junkyard, someone grabbed the m62 but not the intake manifold, I grabbed that intake manifold and removed the previous one. The cores are STUCK in the one from ZZP.
Now I have the new manifold I am paranoid to screw with the laminovas lol I do have water injection too and will install a large water radiator up front, after the stock one.
Thank you for your help.
Smc252
Nov 8, 2021 12:40 PM
iToastie
Nov 6, 2013 01:02 PM
xcmx
Aug 5, 2012 12:14 AM
SS1
Jul 16, 2012 11:07 AM
jwolf8604
Jul 9, 2008 04:51 PM
