Problems with 2.9 Pulley.
Old Jun 9, 2008 | 07:37 PM
schamsy's Avatar
Well I've got stage 2 and its seems pretty obvious that a 2.9 is safe with stage 2. Has ANYONE had a problem resulting from putting a 2.9 pulley on? I'm sceptical about putting it on.
Problems anyone???
Old Jun 9, 2008 | 07:40 PM
turboecotec02's Avatar
I have 2.9. 15 psi comes at 4 grand instead of 4.5 But Still not boosting over 15. Maybe limited i dunno.
Old Jun 9, 2008 | 07:43 PM
lsjwannabe's Avatar
your injectors will go static, but go ahead and do it sense everyone else seems to think it is that great
Old Jun 9, 2008 | 07:45 PM
chad463's Avatar
I put a 2.9 and now I am going for 60lb injectors. My car never ran good when I put my 2.9 and vibrant header so one of the two made my car slower than before.
ssmokin's Avatar
Old Jun 9, 2008 | 07:46 PM
SlowBalt_06's Avatar
when i had the 2.9 my idc was at 98 at6800 rpms
Old Jun 9, 2008 | 07:48 PM
lsjwannabe's Avatar
80% is the standard capacity for most injectors. Your pid for idc's could be off to
with the 2.8 my idc was at 109 %
Old Jun 9, 2008 | 07:49 PM
Mss26's Avatar
this useless post has been brought to you in part by.... a typical cobaltss member
does anyone have solid information like logs from hpt that show a 2.9 is not good on stage 2? i'm tired of seeing these posts and people saying "yes" or "no" without backing it up.
alot depends on where you live
Old Jun 9, 2008 | 07:50 PM
Mss26's Avatar
see this is an example of a helpful post where he has posted his idc with a 2.8 pulley without trying to make anyone look stupid
Old Jun 9, 2008 | 08:03 PM
lsjwannabe's Avatar
depends on your elevation for the question to be answered but at sea level you are screwed
your beloved stage 2 and a 2.9" pulley 115% idc's and is that 5* of knock i see oh my.
Old Jun 9, 2008 | 08:05 PM
yea with the 2.8 i have 6 degree's of knock with stock plugs hehe
Old Jun 9, 2008 | 08:10 PM
Bika's Avatar
Fail Less.
i have multiple logs from different cars that prove the 42# injectors were overworked with just the stage 2 pulley and gm tune. nothing else done except the stage 2 and i was seeing 20msec pulsewidths, 110% idc. with a 2.9" i was in the 130% range and 22msec pw. it would likely be the death of my car had i kept running it.
high altitudes and low air density places are the only times people can get away with smaller pulleys on stage 2.
Old Jun 9, 2008 | 08:12 PM
yea but i drive my car like a girl..i maybe take jump on it 2 times a month and when i do i shift at 6k,,,i never get any races its weak around where i live
Old Jun 9, 2008 | 09:59 PM
Mss26's Avatar
well that spoils my fun.... i have my 2.9 on the way but now i'm having second thoughts... althought i'm at 800 feet above sea level that doesn't make me feel much beter
although from other posts people have said you can safely lean out the rich gm tune and you will no longer be maxing out the idc's.. i don't know how true that is.. but if it is true....
then who is flying to winnipeg to tune me?
Old Jun 9, 2008 | 10:17 PM
Bika's Avatar
Fail Less.
if your injectors are maxed, a smaller pulley will only work them even harder. the leaner afr resulting from smaller pulleys is a result of the injectors not being able to supply the demanded fuel. my afr was dangerously lean with the 2.9". i saw no gains in my 1/4 mile times or trap speeds.
Old Jun 9, 2008 | 10:22 PM
zackss's Avatar
so basically i would be better off with at 3" pulley with 42# injectors? rather than a 2.9
Old Jun 9, 2008 | 10:24 PM
sput's Avatar
This is good info
What about compared to the gm stage 3 pulley sized at 76mm or 2.99? I realize it's not a big size difference from the gm stage 2 pulley but was curious since I have all three.
Old Jun 9, 2008 | 10:27 PM
Mss26's Avatar
on a side note... what, if anything, (besides hp tuners) can measure injector duty cycle? can an interceptor?
Old Jun 9, 2008 | 10:28 PM
shutzero's Avatar
damn, so i bought the pulley for nothing lol
Old Jun 9, 2008 | 10:42 PM
Bika's Avatar
Fail Less.
Originally Posted by sput
This is good info
the gm stage 3 pulley is basically a 3" pulley that you are paying over $100 for. .01" isnt going to do a thing.
the interceptor will not display your IDC%. an interceptor will display injector pulsewidth, which is actually a better indicator than IDC in most cases for measuring injector performance. dont concern yourself too much with the IDC%. all it does is provide a calculation based on pulsewidth, engine load, rpm, etc. HPTuners isnt the most accurate calculation of IDC. 19msec - 20msec is the pulsewidth where an injector is completely static (lost control of itself, cannot provide any more fuel, packing up its **** and going home)
yes.
Old Jun 9, 2008 | 10:46 PM
sput's Avatar
Thanks Bika
Old Jun 9, 2008 | 11:01 PM
Mss26's Avatar
yes.
thanks!, i appreciate your help. I've been thinking of getting an interceptor and thats one more reason in favour of it.
everybodies car is different so it's probably best if i get one and see what my own pulse widths are before i put on the 2.9 i already bought lol.
Old Jun 9, 2008 | 11:05 PM
sput's Avatar
Hey guys, I found this post that contains a formula for converting the injector pulsewidth into IDC. This should be useful for those with the interceptor and wanting to figure out IDC's.
https://www.cobaltss.net/forums/show...dth#post644739
Edit: even easier.. more searching revealed this website: http://www.stealth316.com/2-calc-idc.htm
just plug in the rpm and ipw in ms and it spits out your injector duty cycle %. I'm definitely going to try this out with my different sized pulleys. Thanks again for the good info!
