Procharger C1 in the works..
Old Mar 14, 2013 | 11:24 PM
Shortbus's Avatar
Originally Posted by chood711
Jr said this kit will have the race bypass
Should sound good then!
Old Mar 14, 2013 | 11:28 PM
chood711's Avatar
Did you ever put the Lysholm on?
Never got it. I ended up switching to a Vortech and he was having belt wrap issues with that so it is now the Procharger.
Old Mar 14, 2013 | 11:59 PM
mrbelvedere's Avatar
good luck
Old Mar 15, 2013 | 12:11 AM
killtank's Avatar
I think the only difficulty would be getting a pulley to match the shaft.
Old Mar 15, 2013 | 12:19 AM
This is interesting! Never thought about a PC for a balt
Old Mar 15, 2013 | 12:20 AM
Bluelightning's Avatar
Got Bewst?
Well if it's mounted like the one in that vid he's got some hacking to do if it's going to fit.
Old Mar 15, 2013 | 12:24 AM
JapEatr's Avatar
South Central *********
Its all about CFM
Old Mar 15, 2013 | 12:27 AM
killtank's Avatar
Id rather hack than fine machine, ain't nobody got time for that!
Old Mar 15, 2013 | 01:22 AM
sjc0013's Avatar
Window Licker
Subd
Old Mar 15, 2013 | 06:45 AM
oldskool's Avatar
A centrifugal supercharger is basically a belt driven turbo. Depending on what you want to do with the car, it can be a win-win. You get the compressor efficiency of a turbo without the hassle of oil/cooling lines. But since it's on a pulley, you can only control boost by changing diameter, afaik.
It's a pretty cool idea for an LSJ. As mentioned, the kits out there for v8 platforms are some of the quickest and hassle free ways to bolt on horsepower.
Old Mar 15, 2013 | 08:15 AM
  #36
SPDDMN36's Avatar
I'm interested but i wanna know if the price to power gain and slight weight reduction will be worth it.
Old Mar 15, 2013 | 10:03 AM
  #37
killtank's Avatar
I wanna try this but keep my air to liquid ic
Old Mar 15, 2013 | 12:01 PM
  #38
jittjoey's Avatar
Sub
Old Mar 15, 2013 | 12:08 PM
  #39
ssyellow's Avatar
Post for later.
Old Mar 15, 2013 | 12:28 PM
  #40
574's Avatar
574
subd
Old Mar 15, 2013 | 01:54 PM
  #41
microgab's Avatar
I would be down to change my TVS if the results are good
Old Mar 15, 2013 | 02:32 PM
  #42
Shortbus's Avatar
This should net some great results, but I think will be more expensive to some people. That said for price, power, and Effiency I would still go for a turbo swap.
Old Mar 15, 2013 | 02:51 PM
  #43
armcclure's Avatar
Subd
Old Mar 15, 2013 | 02:57 PM
  #44
newt's Avatar
Ditching the AC unit and mounting it in that location?
My buddy set one up on his 3400 Cav back in the day...they work well, he put down ~400whp on that setup.
Pretty simple if you don't mind ditching the AC unit.
Should be cool to see tho
Old Mar 15, 2013 | 03:14 PM
  #45
Area47's Avatar
Rent me! per hour
cut a hole in the hood and put an f3r on it.
Originally Posted by mrbelvedere
good luck
fun trip down memory lane isn't it
Old Mar 15, 2013 | 03:18 PM
  #46
Got Bewst?
Please explain
Old Mar 15, 2013 | 03:24 PM
  #47
Area47's Avatar
Rent me! per hour
someone on here did a pc setup before. d1 won't fit due to lack of room. c1 produced lack luster power for the work put into it
Old Mar 15, 2013 | 03:56 PM
  #48
IonNinja's Avatar
^^^^^^^^ I was just going to say...hasn't this been done before?
Old Mar 15, 2013 | 04:25 PM
  #49
Area47's Avatar
Rent me! per hour
https://www.cobaltss.net/forums/comp...t-ss-sc-85133/
Old Mar 15, 2013 | 05:14 PM
  #50
armcclure's Avatar
Yay centri! Turbo lag with every shift!
J/k.
