Which pulley?
So far I have a stage 2 kit and ingalls tourque dampener installed on my car. I want to get a Nates pulley, but what size is best. I dont want to buy new injectors or get a tune now because I just had the kit installed.
I fugure I can just swap them off before I take it into the dealer. I am looking anywhere from the 2.8 to the 2.9...Which one would be the best idea and wouldnt need any other supporting mods? |
2.9 .... people do 2.85 but thats really pushing it. i have a 2.8 with 60#s on a custom tune and i am really riding the edge of needing cooling mods. so it sounds like a 2.9 would suit you well.
I'm running a 2.8 and stage II injectors but my altitude here is 3500 feet. I haven't had any issues at all.
Originally Posted by spaz
(Post 1907124)
I have gm stage 2 with a 2.85 ive been running it that way for about 6 months and im fine. but i also have a cobra h/e my injector duty cycle gets to about 110 at 7100 rpm but if i shift at like 6800 im fine its not that bad.
i have 2.9 with 42# ers and my IDC is 110-115 at 6400... FAIL! go 2.8 and 60's or 2.9 with 60's ...
Originally Posted by Darkmanx
(Post 1907132)
Originally Posted by ClownFart
(Post 2659372)
I want to know what idc's people are getting with 42#'s a 2.9 and meth with a tune for around 11.7 to 11.9afr. Mainly beacuse thats what I want to start running this fall, but I dont wanna jack this guy's thread so if someone has the answer to this shoot me a pm, thanks. |
Wow 6 months old guys...lol...anyway I went with the 2.9 and in about two weeks I am gonna get my car tuned for the 2.8 with 60s.
Originally Posted by johnladow07
(Post 2659547)
I would go with a 2.8 60s and a cobra heat exchanger.. you will be fine! |
i already have the parts...just waiting for my header/dp to arrive...60s 2.8....
(Post 2660576)
2.9 is the lowest you should go without upgrading to 60lbers. Also, this will be pushing your idc's pretty high. Depending on your tune, even though its a gm stage 2 tune, they can slightly differ, and climate etc. But depending on your stuff, your idc's could be over 100%, watch that.
Haha...look at when I made this post....February....Thanks though...lol
you can run a 2.3 no problem.. go for it make sure you use stock plugs though
Is dropping to a 2.9 even worth it if you have a stage 2 pulley...noticeable benefits?
ehhh the 2.9 slights you a little bet time, but mainly the thing you will notice is the sound kicking in slightly sooner and the boost hits harder and sooner.
alrite so it sounds like a good idea...but im also in FL at sea level so i dont wanna run my injectors static......what you think?
personally if it were me mate i would stay with the stage 2 pulley. It really isnt worth pushing your injectors that hard for a little extra boost. Your 1/4mile times would barely drop, and you would heat soak even faster.
My 2 cents is its not worth it, especially if you dont have cooling mods. |
