Which pulley?
Old Feb 2, 2008 | 11:05 AM
johnladow07's Avatar
Which pulley?
So far I have a stage 2 kit and ingalls tourque dampener installed on my car. I want to get a Nates pulley, but what size is best. I dont want to buy new injectors or get a tune now because I just had the kit installed.
I fugure I can just swap them off before I take it into the dealer. I am looking anywhere from the 2.8 to the 2.9...Which one would be the best idea and wouldnt need any other supporting mods?
Old Feb 2, 2008 | 11:11 AM
braineater's Avatar
2.9 .... people do 2.85 but thats really pushing it. i have a 2.8 with 60#s on a custom tune and i am really riding the edge of needing cooling mods. so it sounds like a 2.9 would suit you well.
Old Feb 2, 2008 | 12:13 PM
spaz's Avatar
I'm running a 2.8 and stage II injectors but my altitude here is 3500 feet. I haven't had any issues at all.
Old Feb 2, 2008 | 12:17 PM
The Punisher's Avatar
same here...I live in "Mile high" Denver...running 2.8 pulley with 42's and a custom tune with HP tuners
Darkmanx's Avatar
I have gm stage 2 with a 2.85 ive been running it that way for about 6 months and im fine. but i also have a cobra h/e my injector duty cycle gets to about 110 at 7100 rpm but if i shift at like 6800 im fine its not that bad.
Old Jul 28, 2008 | 07:03 PM
ClownFart's Avatar
i have 2.9 with 42# ers and my IDC is 110-115 at 6400... FAIL! go 2.8 and 60's or 2.9 with 60's ...
Old Jul 28, 2008 | 07:46 PM
MidnightNB's Avatar
Maybe this has to do with tuning? If you command a leaner afr, wouldnt your idc's go down? What afr are these 2 cars tuned for? That being said, if your keeping the stage 2 tune your car is commanding a much richer afr and probably gonna see very high idc's if I'm not mistaken.
I want to know what idc's people are getting with 42#'s a 2.9 and meth with a tune for around 11.7 to 11.9afr. Mainly beacuse thats what I want to start running this fall, but I dont wanna jack this guy's thread so if someone has the answer to this shoot me a pm, thanks.
Old Jul 28, 2008 | 07:49 PM
Wow 6 months old guys...lol...anyway I went with the 2.9 and in about two weeks I am gonna get my car tuned for the 2.8 with 60s.
Old Jul 28, 2008 | 08:22 PM
thatotherguy's Avatar
How much money do you have to spend???
I would go with a 2.8 60s and a cobra heat exchanger.. you will be fine!
Old Jul 28, 2008 | 11:22 PM
i already have the parts...just waiting for my header/dp to arrive...60s 2.8....
Old Jul 28, 2008 | 11:25 PM
oh ok gotcha
Old Jul 28, 2008 | 11:41 PM
Zach06CobaltSC's Avatar
2.9 is the lowest you should go without upgrading to 60lbers. Also, this will be pushing your idc's pretty high. Depending on your tune, even though its a gm stage 2 tune, they can slightly differ, and climate etc. But depending on your stuff, your idc's could be over 100%, watch that.
Old Jul 28, 2008 | 11:44 PM
Haha...look at when I made this post....February....Thanks though...lol
Old Jul 28, 2008 | 11:46 PM
SlowBalt_06's Avatar
you can run a 2.3 no problem.. go for it make sure you use stock plugs though
flash13brandon's Avatar
Is dropping to a 2.9 even worth it if you have a stage 2 pulley...noticeable benefits?
Old Jul 28, 2008 | 11:48 PM
ehhh the 2.9 slights you a little bet time, but mainly the thing you will notice is the sound kicking in slightly sooner and the boost hits harder and sooner.
Old Jul 28, 2008 | 11:55 PM
alrite so it sounds like a good idea...but im also in FL at sea level so i dont wanna run my injectors static......what you think?
Old Jul 29, 2008 | 12:12 AM
personally if it were me mate i would stay with the stage 2 pulley. It really isnt worth pushing your injectors that hard for a little extra boost. Your 1/4mile times would barely drop, and you would heat soak even faster.
My 2 cents is its not worth it, especially if you dont have cooling mods.
Oct 20, 2015 09:56 PM
SSLOW06
Oct 1, 2015 07:21 PM
patooyee
Oct 1, 2015 01:07 PM
Sep 30, 2015 07:22 AM
ChrisTutoki
Sep 24, 2015 08:39 PM
