Pulley size change question
Old May 22, 2009 | 09:37 AM
06G85's Avatar
If I went from the stock 3.3" pulley to a 3 inch pulley, would I have to change the belt or retune and what differences would I see?
Old May 22, 2009 | 09:50 AM
ShortStack's Avatar
Belt might need to be changed... You may or may not have slip.
You will be hurting things if you just switched pulleys. You need to buy larger injectors as well... and with larger injectors you HAVE to get a tune...
Do it safe.
Old May 22, 2009 | 09:53 AM
light'bolt's Avatar
smaller pulley=more air
more air=more fuel
more fuel=larger injectors
larger injectors=Tune
Old May 22, 2009 | 09:54 AM
ShortStack's Avatar
^^ Yeap.
Old May 22, 2009 | 09:56 AM
06G85's Avatar
THANKS GUYS!!!! ") I didn't realize that even just a little change in the pulley size had a bigger effect on performance than I thought!
Old May 22, 2009 | 09:57 AM
ShortStack's Avatar
Yea.. they are really pushing the stock injectors to the limit...
brandon04
Oct 21, 2015 07:04 AM
patooyee
Oct 15, 2015 05:11 PM
nathan112i
Sep 30, 2015 07:12 PM
ChrisTutoki
Sep 24, 2015 08:39 PM
