Pulley and tune question
Old Apr 4, 2011 | 03:29 PM
troyss's Avatar
Ok this is for a friend.
He has ordered the zzp stage 3 kit. He's got the kit now the 2.8, 60's, and pcm etc...
He needs his car to drive to work and has no other rides soy question is can he hook up the 60's and zzp pcm and run it with the stock pulley until friday? Pulley puller is running late.
Wilo this be ok?
Thanks
Old Apr 4, 2011 | 05:19 PM
blackcobalt1986's Avatar
no i wouldnt recomend it.
Old Apr 4, 2011 | 05:28 PM
murphy0789's Avatar
Mitch
NO the pcm is tunned for the 2.8 not the stock pulley.
Old Apr 4, 2011 | 05:30 PM
ecot3c inside's Avatar
You can, might be a little rich. Won't hurt anything if you did.
Old Apr 4, 2011 | 05:33 PM
the_cobalt_kid's Avatar
this. ONLY WAY i can see it MAYBE working is if you didn't go into anywere were there would be boost on the 2.8 BUT i'd still just wait. My advice... WAIT!!!!!!
Old Apr 4, 2011 | 05:45 PM
alleycat58's Avatar
Yeah, it's safer to run a bigger pulley on a tune meant for a smaller pulley than the other way around. Worst case scenario it's going to run pig rich. The question is why would he do this though? Like I know the "ZOMG NEW PARTS" feeling, but why drive a car that's not going to have an ideal tune on it, especially when it's your only transportation. The best idea is to wait until you can install the whole kit all at once.
Old Apr 4, 2011 | 05:47 PM
okay, if you were to throw a smaller pulley on a car that still had smaller injectors. like a 2.6" pulley on 42# injectors, yes there would be PROBLEMS.
But OP what your asking is totally fine and in fact I have switched pullies up and down many times and the WOT fueling and fuel trims generally stay the same most of the time.
bingo.
Last edited by ecot3c inside; Apr 4, 2011 at 05:47 PM. Reason: Automerged Doublepost
Old Apr 4, 2011 | 05:51 PM
05Slowline's Avatar
just don't boost it lol
Old Apr 4, 2011 | 07:57 PM
pretty sure he can boost all he wants...
Old Apr 4, 2011 | 07:58 PM
alleycat58's Avatar
Yeah, he's running a larger pulley than what it's tuned for, boost away.
Old Apr 4, 2011 | 08:00 PM
Perfect.disguise's Avatar
Its fine.
Old Apr 4, 2011 | 08:05 PM
troyss's Avatar
I understand that he should wait. Its his only car and he sent his old pcm in for the zzp one and its his i only car/ride to get to work. So it should be ok? Just when friday hits when the puller gets here just swap em over and it will be fine?
Thanks guys much appreciated
Old Apr 4, 2011 | 08:08 PM
chris88z24's Avatar
I hope he's used to driving in limp mode and/or doesn't have a catalytic converter.
Old Apr 4, 2011 | 08:10 PM
troyss's Avatar
Explain please?
05Slowline's Avatar
yea go ahead an boost it up, clog the cat up......
Old Apr 4, 2011 | 08:13 PM
alleycat58's Avatar
cats are overrated anyway.
Old Apr 4, 2011 | 08:14 PM
troyss's Avatar
So since its a stock pulley it will clog the cat up? Lol
A 2.8 it won't
Old Apr 4, 2011 | 08:20 PM
alleycat58's Avatar
A 2.8 it won't
It might. The fueling is calculated assuming a 2.8 pulley. The bigger the pulley (stock is....3.35?....I think), the richer it gets. The richer it gets the more fuel you're throwing into the cat. The more fuel you throw into the cat.....well you get the point.
EDIT: That being said, assuming he doesn't have a long commute, he's not going to be beating the **** out of it, and it's only for 4 days, it shouldn't completely fry the cat. Usually takes a couple weeks and a few good WOT runs to do that.
Old Apr 4, 2011 | 08:21 PM
troyss's Avatar
Good point man thanks
Old Apr 4, 2011 | 08:25 PM
Chevycobaltss3's Avatar
lmao............. the car is tuned via maf or ve so if your using a larger pulley then the tune sent you will run very very very bad fuel trims. Yes you can drive the car but you can get issues like s cel popping up, clogging the cat, making the plugs foul out, making issues with the ringlands and rings... ect so be weary.
Old Apr 4, 2011 | 08:26 PM
05Slowline's Avatar
Good point mam thanks
Old Apr 4, 2011 | 08:27 PM
Just stay out of it and it wont be much diff than being easy on a 2.8.
Old Apr 4, 2011 | 08:30 PM
doubt cat will clog in less than a week though, might take awhile longer than that. ss3 has a good point, but those may never happen.
OP just tell your friend to go for it.
D_Rob's Avatar
Well, I'm going to assume there are different fuel values, and timing tables, and that common sense politely says there is a guy named Murphy. You may have heard of him. He has a law, and it states that if it can go wrong it will go wrong, so, in light of this no.
My car is my DD as well, there's no way I would risk it. When/If you come back say... Tuesday and it's like "ZOMG meh cah is FTL", the opinions will be a bit different when you tell them what you did, and how it messed something up. Meanwhile, we'll all still be driving our cars. My .02
Old Apr 4, 2011 | 08:35 PM
no timing is still the same, fuel tables? lsj's have very few. Most that will happen IMO is you will run a little rich. If I was in this situation I would wait, but if I couldn't wait... I would defiantly do it, and if it turns out it's too rich it is only another 15mins to swap to stock.
