question about AEM UEGO
Old Jul 25, 2008 | 04:54 PM
BlackSSnTN's Avatar
i've got stock header/dp, where do I need to mount the Bosch Sensor for the UEGO? Sorry to post a new thread over this, but I looked for 20 minuted and could find ****. I"m sure it's noted in about 40 different places and I probably overlooked every last one of them. All help is greatly appreciated!!
bump!
Last edited by BlackSSnTN; Jul 25, 2008 at 04:54 PM. Reason: Automerged Doublepost
Old Jul 25, 2008 | 05:13 PM
jimmyfoxx's Avatar
18" from the block. before the d/p
Old Jul 25, 2008 | 06:26 PM
BlackSSnTN's Avatar
so do I need to weld in the bung it came w/? someone told me I can remove the O2 Sensor before the downpipe and place the new one in it's place, and just clear the CEL when I have it tuned? that doable?
Old Jul 25, 2008 | 09:56 PM
hungryhip-ccp's Avatar
umm no... thats what you car uses to adjust your AFR the sensor needs to be 12-36 in from the head read the instruction that came with it, unless you bought it used... and its also one of the shitiest WB ive ever had...
Old Jul 25, 2008 | 11:04 PM
theneelster's Avatar
bump!
First o2 sensor before it goes through the cat...that could mean a lot of things.
Old Jul 27, 2008 | 09:13 PM
BlackSSnTN's Avatar
well I dont have an instruction manual. It's a brand new gauge, but the guy I bought it from took it outta the box along w/ all the wiring and sensor, then he lost the box w/ the manual. Hell I got it for $100, I couldnt pass it up. So, i'm gonna go to the local exhaust shop tomorrow and have them weld in the bung that came with it, but I just need to know exactly where to put it....
Old Jul 27, 2008 | 09:46 PM
Doc's Avatar
Doc
Before the cat and between 9 and 3 o'clock. Meaning parallel to the ground is the limit.
Old Jul 27, 2008 | 09:47 PM
After the flex (obviously) but before the cat if you have one.
Old Jul 27, 2008 | 10:32 PM
thatotherguy's Avatar
I thought you could remove that o2 sensor in the downpipe and install it there and just get hp tuners to clear that ****!
Old Jul 28, 2008 | 02:16 PM
BlackSSnTN's Avatar
^^^^^ that's what someone told me, but **** it, i'll just weld in the bung and do the damn thing the right way. I"m takin it to the exhaust shop in a couple hours. They're cutting the cat out altogether, and they're gonna weld the bung in the pipe they put in place of the cat on the 10 degree angle and all that ****, so hopefully it'll work out right! I do appreciate all the help!
Old Jul 28, 2008 | 02:24 PM
Infernokron's Avatar
That's if you don't have a cat. If you have a cat then it will throw off your WB readings, so you have to mount the WB before the cat.
That should work fine, one thing to note though. When you remove the cat you will get a check engine light because you cat isn't operating up to par (in other words the car will yell at you for taking out the cat).
Old Jul 28, 2008 | 03:04 PM
Yeah im catless.. so thats what i think im gonna do is use the stock o2 sensor location and put my wideband o2 sensor in its place
Old Jul 28, 2008 | 03:07 PM
Doc's Avatar
Doc
I don't know if the AEM UEGO will allow you to run wide and narrow band. The LC-1 does and people often replace the forward O2 sensor with the bosch unit that comes with the LC-1. They have to run it as a narrow and wide band but it does it just fine.
Old Jul 28, 2008 | 05:43 PM
BlackSSnTN's Avatar
ok so here's what happened. I went to the exhaust shop, they cut out the cat, welded in a pipe and mounted the sensor in that pipe, basically up toward where the top of the cat would have been, maybe just a smidge lower. 1st. it sounds like total ****. I've got a borla catback w/ stock d/p and header. So I guess that was to be expected. 2nd, the readings on the gauge are bouncing back and forth like crazy. It goes from 12.1 one second right up to 16.8, then back to 14.5, and so on and so forth. That's not normal is it? What have I fucked up?
Old Jul 28, 2008 | 05:50 PM
ohh yeah thats normal (hence why i said the aem is junk ^^^^)
have you ever had a WB before? they all do it but the aem just blows cause you cant do free air calibration
thats the front o2 switching from lean to rich its narrow band thats just the way it is!
go wot its steady as a rock then right?
Old Jul 28, 2008 | 06:20 PM
BlackSSnTN's Avatar
no i've never had one before. and as far as WOT, it's not exactly steady as a rock but it doesnt vary near as much as what it would be at just normal driving speed. so is there anything I can do to make it work better? or is it just somethin that is what it is?
Old Jul 28, 2008 | 10:00 PM
06SS/SC STAGE2's Avatar
If your on a stock tune or for that matter a staged tune it will still rise or fall at WOT. But once you get a tune, the tuner should be able to get your AFR locked in at a specific number. I say get a tune cause now you have removed the cat and will have to at least tune out the rear O2 and any fault codes. Might as well get a full tune at that point.
Old Jul 29, 2008 | 03:03 AM
x2... whats it saying at wot anyways... just curious as to if the cat being gone and flowing more air if your as rich as some..... 10's? 11's?
Old Jul 30, 2008 | 08:00 AM
BlackSSnTN's Avatar
yeah that's exactly what it's reading. But, tuning is the reason I wanted to get the gauge in and working. I've currenty got the car jacked up and torn apart. I got the injectors and plugs changed yesterday, as well as put on a lower billet grille and AVS tail light covers. Now i'm just waiting on my pulley system from Nate so I can put on my new pulley and belt and the Stiffy and go get it tuned
DarrenGC
Dec 24, 2021 01:55 PM
Jan 12, 2016 12:01 AM
brandon04
Oct 21, 2015 07:04 AM
yellow dragon
Sep 28, 2015 09:49 PM
Sep 27, 2015 08:53 PM
