question about supercharger spacer
Old Aug 29, 2006 | 06:33 PM
BlueSS-supercharged's Avatar
hey every one i was looking on the intense web site and notcied the supercharger spacer and was wondering where it says it will take up belt slack, how much would that really be? how about how much with a 2.9 pulley? Would you recomend any thing to go with this to make it function better like should i continue to look for a smaller belt and larger idler pully...kurt
http://www.intense-racing.com/
Old Aug 29, 2006 | 06:52 PM
Halfcent's Avatar
I'm old school
How thick is the spacer? Multiply by 2 and that how much of the belt is getting used up.
Old Aug 29, 2006 | 07:26 PM
06blackg85ss's Avatar
I thinks its about a 1/2 but if your just runnin a 2.9 get the gm stg II belt (30 sumthing $'s at www.cobalt-addiction.com) ... thats more for a 2.5 pulley also gives a little more plenum volume... ( little more top end)
Old Aug 29, 2006 | 09:15 PM
the belt is more of plenum volume or the spacer is?
Old Aug 29, 2006 | 10:26 PM
selfinfliction's Avatar
the spacer, it's not much though
<edit> the volume is important to keep down spikes and provide a more constant flow for higher end turbo setups. our blowers are moving a little below 117liters per second more than than our motors are displacing (just comparing numbers, not calculating in heat and resistance factors), at those numbers, being belt driven you wouldn't see the benefits of it.
Old Aug 29, 2006 | 10:34 PM
Brian MP5T's Avatar
The Spacer is probably not going to do anything but be something to put down in your signature block.
Old Aug 29, 2006 | 11:31 PM
automobiliben's Avatar
I would agree, but Intense said that the spacer was designed so that N20 and Water/Meth kits could be injected post supercharger. That was the real point of it, not to take up slack in the belt or increase plenum volume.
Old Aug 30, 2006 | 09:26 AM
so you wouldnt recomend it unless you were running N2o or water, thanks every one
RaginChopsuey
Oct 27, 2015 01:27 PM
brandon04
Oct 21, 2015 07:04 AM
goaliemo
Sep 28, 2015 01:37 PM
SlowSaturn
Sep 28, 2015 11:03 AM
z28addiction
Sep 28, 2015 12:03 AM
