Quick 2.9" Pulley Question
I've got a 2.9" pulley coming this week to go along with my other mods listed in my sig. Is the 2.9" a simple bolt on mod as in no tuning will need to be done?
Edit: I did do a search but since it's been awhile since I been on here, there's so much info going around on the whole 2.7-2.9" deal, I couldn't find a solid answer.
Speaking of HPTuners, my local performance shop does tuning and I ask if he could specifically tune cobalts and he said yes. Now is HPTuners the only Cobalt tuning software out there or are there others? Sorry, I'm idiotic when it comes to tuning because I've never done or had it done before. I'm slowly learning more and more about it each day though :css.net:
I have seen my injectors max w/the 2.8 at 6200, and others run the 2.8 fine on the stage 2 injectors. If the pulley can be run or not depends on the amount of boost and airflow you are seeing
I've been running a 2.9 with the stock GM Stage tune for quite some time now. No problems whatsoever. You feel a little bit more pull and see a little more boost than the stage 2 pulley.
patooyee
Oct 1, 2015 01:07 PM
