quick question
if your dealership tells you that your warranty is voided because your valve cover is a different cover...i think you officially have the right to sue the pants off them.
you're good brother, it won't affect how the car runs, so it won't void the warranty.
The only way it could void your warrenty is if you remove the valve cover and while its off getting powdercoated you leave the hood up with no protection over the head and valves and it rains and happens to get a nice amoutn of water in the oil and something fails because of it. As long as you think through every step and don't do anything stupif you'll have no problems. Make sure to cover it up real good so nothing gets inside while its off.
or if you pinch the gasket and it starts leaking , a new gasket would be on you to fix it
but if done you shuldnt have any problems at all
just make sure to flush it on the underside to make sure there is nothing that will harm the motor before you put it on
Thanks for the info my car will be parked in the shop where i am geting my rims valve cover and what ever else i can think of to powercoat
nice only haveing to pay for the powder
