quick question take a moment....
Old Aug 24, 2007 | 03:43 PM
clutchmaster's Avatar
i am going to be running a 3.0 pulley, from zzp...airbox mod... and a smaller belt soon. it says that a step colder spark plugs will help stop knock. there only like 10-15 bucks... can i just throw them on there. and still not get a tune. or to lean?? i wont tune untill i get the 42lbs and smaller pulley with a header and d.p
Old Aug 24, 2007 | 03:44 PM
Onyxd04Redline's Avatar
With stock injectors and a 3" you will blow your engine. Stop taking the cheap way out. Do it right
Old Aug 24, 2007 | 03:45 PM
haha damn ok...im new to all this... someone told me with stock everything and just a 3" i will be fine
the pulley modular from zzp and a smaller belt... with stock tune. that i should be fine
Last edited by clutchmaster; Aug 24, 2007 at 03:45 PM. Reason: Automerged Doublepost
Super_SS's Avatar
well that someone prolly has a blown motor now
Old Aug 24, 2007 | 03:52 PM
really haha nah they are running a 2.9 with header exhaust and a tune and intake
so what would you advise me to do?? should i just get injectors spark plugs and a tune??
any help guys?? no need to be dicks about this
Last edited by clutchmaster; Aug 24, 2007 at 03:52 PM. Reason: Automerged Doublepost
Super_SS's Avatar
injectors are most important..that determines the pulley size u can run...bigger injectors smaller pulley,and a tune is a MUST
Old Aug 24, 2007 | 03:54 PM
but what i heard from more then one. is with the stock injectors and stock tune the car should be able to be good for a good amount of time with out a tune yet. just restating what i heard. its only a 3" i think stock is 3"25 + ??
Old Aug 24, 2007 | 03:55 PM
Super_SS's Avatar
just get a gm s2 and ull be a happy man
Old Aug 24, 2007 | 03:57 PM
f that. warranty is up soon. plus with the gm stage two.. i cant up grade pulley size.. unless i go thru like pulley boys or ****. i allready have the pulley mod system coming in two days. id rather make my own little stage kit. gm s2 puts out decent numbers but not for what i want.
and bro no offense but arent you stock??
Last edited by clutchmaster; Aug 24, 2007 at 03:57 PM. Reason: Automerged Doublepost
Old Aug 24, 2007 | 04:07 PM
Super_SS's Avatar
hehehe...oh course..i dont put money into a car ..waste of money and time
42lbs injectors smallest pulley size is 2.8
60lbs injectors smallest pulley is 2.5
u need a tune with all of those...thats just the basics...
Old Aug 24, 2007 | 04:13 PM
Why did you post if you don't want to listen to our answer's? Put it on and see what happens but don't complain if you blow your motor.
Old Aug 24, 2007 | 04:37 PM
well i would listen to your answers but answers like these-----"Stop taking the cheap way out. Do it right"
and this-----well that someone prolly has a blown motor now
how can i not take some offense to it.. i just asked a simple question... and for ur info.. there are people who have ran this set up for a few months... i will be runnning it for 3 weeks tops. untill i get my 2.9 injectors and a tune.
https://www.cobaltss.net/forums/front-page-news-17/cobalt-ss-sc-got-boost-25843/ take a moment and read this thread... he is a moderator.
Last edited by clutchmaster; Aug 24, 2007 at 04:37 PM. Reason: Automerged Doublepost
Old Aug 24, 2007 | 04:49 PM
tlax23's Avatar
^a lot of information has emerged since that thread.
if you want to have a quick, reliable car you cannot take any shortcuts. you are going to at least need injectors and a tune if you purchase a smaller pulley.
if you want to futher enhance your new mods you can do I/H/E of your choice.
take some time and read some posts before you make any decisions. is the cost of a blown motor worth the 200-300 dollars for injectors and a tune?
hope this helps...
Old Aug 24, 2007 | 04:50 PM
matt_SS_205's Avatar
https://www.cobaltss.net/forums/showthread.php?t=25843 take a moment and read this thread... he is a moderator.
not trying to offend you, but you may last a few weeks without a tune or injectors, but you will damage the motor in doing so
Old Aug 24, 2007 | 04:51 PM
yeah alot better then what they were trying to get across.... so ur saying if i am running a 3" for only a few weeks... on stock tune. i will blow motor. cause by mid sept i should have 2.9 smaller belt plugs 42lbs and a tune from tune time???
Old Aug 24, 2007 | 04:54 PM
tlax23's Avatar
there many factors that determine how your engine will function with that setup. it isnt guaranteed that you will blow your motor but it is certain that it will not be good for it. your elevation, the weather, and how you drive your car are just some of the factors that play into it. your IDC's will be too high to run that setup for long before your engine goes
Old Aug 24, 2007 | 04:57 PM
i have no idea what idcs mean... i am really new to the modding thing...
Old Aug 24, 2007 | 05:02 PM
tlax23's Avatar
ok no prob.
IDC=injector duty cycle
think of it as how hard your injectors have to work to supply the correct amount of fuel. anything over 100% is detrimental and the injectors go static (lose control) at 120%
hence why you are being advised to go with larger injectors so they do not have to "work" as hard to supply the car with fuel.
Old Aug 24, 2007 | 05:04 PM
from what i heard is that if you are not beating on your car.. and not redlining it constantly that i should be fine... def since of short of a period i would be running them... in btw 6500 and up i think is when its most prone to become static.... and if im shifting before hand... eh idk im about to not even install. now super pissed
Old Aug 24, 2007 | 05:08 PM
Why would you be super pissed? First mods and fuel mods have been discussed a hundred times already in this forum on a daily basis.
Old Aug 24, 2007 | 05:11 PM
tlax23's Avatar
you sir are correct about most injectors going static about 6500rpm.
BUT you are still overworking your engine just driving normally. i would personally most definetly get injectors and a tune but that is totally up to you.
you car may be alright for a short time period. it may not.
whatever you decide good luck and i hope i was able to help you out. feel free to ask or pm me if you have any more questions.
Old Aug 24, 2007 | 05:13 PM
because i just spent money... and its my first mods... and from what i heard this was a safe set up. i just spent money and now i cant install.. been kinda looking forward to install as well. no need to be a god damn jerk off... when a. im new. b. i asked a very simple question c. you had no reason to be snappy . thank you tlax23 for not being a dick
Old Aug 24, 2007 | 05:39 PM
Pyros777's Avatar
I didnt think he was being "snappy".
It seems to me you're trying to move too fast. Take your time, search the forums, and come up with the right combination of mods for YOURSELF (of course asking questions along the way) instead of just buying whatever your buddy says will work. Like the old saying goes "If you want something done right, do it yourself."
Right now you need to get a little more humble, realize where you are at, and mod accordingly. Don't try to get ahead of yourself just because you spent money and want to play NOW.
Just some advice. Take it or leave it.
Old Aug 24, 2007 | 05:52 PM
thanks pyros... just dont apr. that attitude from people who are not even modded
Old Aug 26, 2007 | 03:52 AM
cbevington6's Avatar
[QUOTE=clutchmaster;1370927]i just spent money and now i cant install.. QUOTE]
Ok so i'm modded, i did it myself, i did the research and i know what i'm talking about. You should have figured out what you were getting before you got. I still dont get why you ask the initial question AFTER you bought everything. If you do this you might not blow your engine but you will tear it up. And as for coming on here a newbie and talking **** to people that know a lot more than you and your buddy is just stupid.
My advice is quit being a dick **** and do the research, save up your money, and buy the **** you need to do it right. You will be a lot happier with the outcome in the long run. I was.
brandon04
Oct 21, 2015 07:04 AM
dennis69
Oct 20, 2015 07:39 AM
patooyee
Oct 15, 2015 05:11 PM
Extremespeed
Sep 29, 2015 04:34 AM
Iceberg
Sep 28, 2015 01:31 PM
