Quickie - Removing S/C
Old Mar 22, 2008 | 07:32 PM
Netsyphen's Avatar
Is there anything I need to know about removing the S/C. Will it leak any fluids, what needs to be removed, what is the easiest way to remove it?
My stage 2 bolt heads are stripped out, and I can't vice them out so I am gonna need to drill them out, thus i'm going to need to take the s/c off.
Old Mar 22, 2008 | 07:58 PM
Stouffer's Avatar
Real easy. Disconnect sensors, 15 mm wrench for pulley tensioner to get the belt off and then whatever size the four bolts are holding it on.(sorry I can't remember). If you need a hand let me know.
btw-posted in the wrong section b4 you get flammed for that.
Old Mar 22, 2008 | 10:14 PM
JonyyB's Avatar
Site Founder
thread moved out of "2.0L LNF SS Turbocharged General Discussion" to "2.0L LSJ Performance Tech"
Please post in the correct sections
Old Mar 22, 2008 | 10:17 PM
Sunburst_SS's Avatar
no, no fluids will leak out. You need to take the air intake pipe off the throttlbe body, removed the evap purge line, the brake booster line, the scip sensor connector and the throttle body connector. take the 2 10 mm bolts off that hold the intercooler fill "jug" to the blower....take the belt off. Then the 4 bolts that hold the blower to the manifold are 6mm allen head bolts I think.....just be careful not to damage the gaskets when you take it off.
GaryGibblez
Jan 14, 2020 10:35 AM
brickloaf
Show & Shine
56
Jun 18, 2019 12:51 PM
Extreme Dimensions
Sep 24, 2015 05:24 PM
katahdin_lubricants
Sep 20, 2015 07:24 PM
Getaway_Driver
Sep 8, 2015 09:41 AM
