Really Confused Here Need Some Opinions
Old Apr 13, 2009 | 08:15 AM
SSLOW06's Avatar
So I Been Working On The Car Since Friday Long Story Short I Have About Every Bolt On U Can Get For A 2006 Ss Cobalt .
Dam Thing B00sting To About 22 Psi 2.8 Pulley And 60,s
Ls4 Tb Alcohol Inj Full Exhaust 3in Cai Dual Pass Plate Front Mount Heat Exchange Option B Tank Like I Said Just About Everything. ALSO HAVE MY SILENCER HOLES PLUGGED AND MY BLOWER PORTED A LITTLE FOR THE LS4
This Is Really Weird Although The Car Is Running Fine At Idle Its A Little Rough I Got A Zzp Pcm Flash But Will Def Get Tuned Again Soon .
I Have A Scan Gauge Were I Will Check My Iat"s In The Morning Im Exhausted .
If Anybody Has Any Ideas Let Me Know Thanks !
__________________
Old Apr 13, 2009 | 08:20 AM
JimzSS's Avatar
22psi with a 2.8" ?
much to high
sounds like an exhaust restriction such as a defective convertor
Old Apr 13, 2009 | 08:24 AM
2MCHBoost's Avatar
What is your exhaust setup?
Old Apr 13, 2009 | 08:43 AM
SSLOW06's Avatar
JBP HEADERS 3' IN CTLESS DOWN PIPE 2.5' MAGNAFLOW
Old Apr 13, 2009 | 09:25 AM
KillinKrullin's Avatar
well i supose its not the cat.... when does youre meth start spraying?
Old Apr 13, 2009 | 09:28 AM
JimzSS's Avatar
my 2.8" only boosts to around 16ish.....22 is to high
check your spark plugs
with the 2 .8 they should be gapped around .038"
Old Apr 13, 2009 | 09:32 AM
383_Stroker's Avatar
Mouse nest in downpipe?
Old Apr 13, 2009 | 09:38 AM
2MCHBoost's Avatar
Whats the weather like? Cold weather will increase boost
Old Apr 13, 2009 | 10:24 AM
my 2.7 in really cold weather hit 20psi
my thoughts: something is blocking it up in the exauhst, typically the cat is the the culprit. but since you have no catalytic converter we look in other places. What jim said (check you spark) if your motor is not efficiently burning the air and gas its given this can build up pressure in the intake manifold, resulting in higher boost readings.
another odd thing it might be is your gauge? ive never heard of one reading bad but i supose it can happen. How much max vacuum do you run? it should be right around 23.
Old Apr 13, 2009 | 10:27 AM
scott allen's Avatar
Could it be the bypass valve on the blower?
Old Apr 13, 2009 | 01:58 PM
SSLOW06's Avatar
I HAVE THE STOCK GAUGAE ASWELL AS A SCAN GAUGE WICH IS DIGITAL . AS FOR THE EXHAUST BEING CLOGGED UP IM THINKING NOT CUZ THE CAR WAS DRIVEN INTO THE SHOP JUST FINE AND I DIDNT TOUCH IT JUST WORKED ONT HE ENGINE .
IT WAS ABOUT 35 LAST NIGHT NOT THAT COLD AT ALL
I HAVENT PLAYED WITH THE METH BUT IT COMES SET AT 10LBS AUTOMATIALLY SO I LEFT IT AS IS UNTIL I FIGURE ALL THIS OUT
IS THAT THE VALVE THAT READS THE BOOST AND OPENS FOR THE COOLANT ?
Old Apr 13, 2009 | 01:59 PM
ShortStack's Avatar
35 is cold...
20psi on a 2.8 is WAY too high.. no matter how you're going to try and justify it.
A BOOST bypass will have nothing to do with the coolant...
it opens when you let your foot off the gas so there is no pressure being made.
Last edited by ShortStack; Apr 13, 2009 at 01:59 PM. Reason: Automerged Doublepost
Old Apr 13, 2009 | 04:21 PM
SSLOW06's Avatar
Originally Posted by ShortStack
35 is cold...
DAM SO WAT IN THE WORLD CAN THIS BE .
IM NOT GONA TOUCH THE CAR TILL TOMORROW MORNING MAYBE I WILL TAKE IT TO A TUNER AND HE CAN FIGURE IT OUT FOR ME ALTHOUGH ITS JUST CRAZY !
I HAVE THE 2 STEP COLDER PLUGS THEY COME PREGAPED AND THEY WERE PUT IN BRAND NEW
bump foe some help
Old Apr 13, 2009 | 04:26 PM
ShortStack's Avatar
What plugs are you using?
They come pre gapped smaller than they should be... and should be widened up a bit.
Old Apr 13, 2009 | 04:30 PM
Buy a new bypass valve and i think you will be ok.Because if it aint working right in can cause you to over boost just like a blow off valve on a turbo car.
Old Apr 13, 2009 | 04:31 PM
ShortStack's Avatar
That would be the wastegate that adjusts boost level...
And it bleeds the air to keep boost level down.
Old Apr 13, 2009 | 04:45 PM
HunterKiller89's Avatar
colder weather would never raise boost more than 1psi
And OP, PLEASE stop typing in all caps.
Old Apr 13, 2009 | 04:47 PM
2MCHBoost's Avatar
Maybe he can't read the gauge right
Old Apr 13, 2009 | 04:48 PM
the bypass valve is completely shut when WOT on all cars..a broken bypass valve cannot cause overboosting like a BOV can on a turbo car, because the supercharger is directly proportional to engine RPM, unlike a turbo which would spike whenever you shift. A broken bypass valve will either keep the valvre closed under idling/cruising conditions, which wouldnt affect psi under WOT, or it would be partially open under WOT, which would cause a reduction in psi
Something is clogged somewhere....thats really all there is to it. Have you or anyone else ever messed with your cam timing or anything else using that chain? If not, then theres some sort of clog in either the exhaust track, or the intake manifold
Old Apr 13, 2009 | 04:52 PM
ShortStack's Avatar
^^ what im trying to say is that it is not the blow off valve on a turbo system that will cause over boosting..
That would be the wastegate.
ok it was just a thought,im confused now,cant wait to see what it is.
Old Apr 13, 2009 | 06:05 PM
Bika's Avatar
Fail Less.
the stock gauge doesnt even read above 20psi unless its a t/c gauge. if theres no restriction in your exhaust, something may be restricting your intake manifold. look down in there maybe the laminovas collapsed or someone left something inside.
your bypass valve cant make you boost higher. only bleeds off boost under idle/vac. its always closed when your w0t.
Old Apr 13, 2009 | 06:12 PM
ok. i just misunderstood ya. I was explaining more for the OP tho. I figure u already know how the bypass valve works
OP, you also might wanna try taking the end plate off and checking out the laminovas, but i'd start with the exhaust..maybe the muffler got clogged up or broke apart inside
Old Apr 13, 2009 | 06:13 PM
maybe a faulty gauge?
Old Apr 13, 2009 | 07:05 PM
it would be a faulty sensor since he's using more than just the stock gauge to get the same reading, but possibly?
