rebuilding
Old Mar 14, 2014 | 03:38 PM
bobby71189's Avatar
rebuilding
Looking to rebuild my lsj. Car has a lil over 100k miles and I'm looking to put a tvs on after the rebuild. Can anyone help me in what parts I would need to make this happen. My end goal is 330ish hp. Thanks
Old Mar 14, 2014 | 03:42 PM
WVU_SS's Avatar
That's pretty vague there. I mean, rods, pistons, sleeves. Valve springs, cams, might as well port and polish the head while you have it off.....
Old Mar 14, 2014 | 03:43 PM
Does it need a rebuild or does it still run? 330hp is just fine for the stock motor, and im sure it can hold up to a tvs. 100k isnt a ton
Old Mar 14, 2014 | 03:46 PM
WVU_SS's Avatar
I'm at 85K and am not worrying about building it. You'd need to push the TVS decently far to need a rebuild. I'll be getting mine in, in about a month, planning on around 350hp and am not worrying at all. Unless it needs done, I would leave it alone.
Old Mar 14, 2014 | 03:51 PM
bobby71189's Avatar
The engine runs good still. I jus dont want to blow it after modding it heavily.
Old Mar 14, 2014 | 03:53 PM
bobby71189's Avatar
For example, porting the head n possibly mild cams along with a tvs. Is that not stressing the bottom end at all?
Old Mar 14, 2014 | 03:56 PM
Anything with a tvs will be perfectly fine with the stock bottom end and a good tune, unless youre looking to push close to 400whp.
If youre only looking for about 330whp, you probably wont even need cams or a ported head. Just sayin
Last edited by Slowbalt2000; Mar 14, 2014 at 03:56 PM. Reason: Automerged Doublepost
574's Avatar
574
With a good tuner it should be good but if you want piece of mind throw some diamonds in there and total seal rings. You should message lsjion about getting your head ported he does great work and half the price of others
Old Mar 14, 2014 | 06:21 PM
mrbelvedere's Avatar
you don't just ******* throw pistons and rings in before you do that you need to worry about the condition of the bores and such
Old Mar 14, 2014 | 06:23 PM
Na man just slap em in there. **** measuring
Old Mar 14, 2014 | 06:25 PM
574's Avatar
574
I thought pulling the block and having it machined was implied
TheSandMan
Sep 20, 2015 06:02 AM
Regalgs
Sep 17, 2015 02:27 PM
calo247
Sep 8, 2015 12:29 AM
DisJuan
Sep 7, 2015 01:51 PM
