Recklessactn Rebuild Thread
lol nice infliction, i kinda want to debate putting in pistons, thoughts? I just want to make good reliable power around 300 whp, how much more is it going o cost/time will it take to drop pistons in?
Happy Birthday to MAX!!!
don't drink too much. this is what's in your future 3 years from now...
so don't die on me man. i'll have her waiting for you 3 years from now.
Last edited by PerformanceClutches; Feb 25, 2010 at 11:43 PM. Reason: Automerged Doublepost
When the head comes off i'd inspect the cylinders/piston tops. To do the piston swap expect at least another 5 hours labor minimum. They also come at a price, a little noiser/tiny bit more oil burning.
*Edit*
And to top it off, add the cost of new rod bearings(why reuse if they are being taken apart anyway) which are cheap around $25 for the set, 8 new rod bolts(dont remember price), and the cost to rehone the cylinders. Then you have to worry about proper ring gap and yadadada just not worth it if you catch my drift.
*Edit*
I only built mine because I had planned on spraying it a **** ton but when I lost my job plans changed of course. Now it's just a measly stage 2 car with pistons in it LOL.
We could always just swap motors too Max
Not worth it for his plans imo, his 'problem' isn't even bad. He SHOULD get in the cylinder with a boroscope to see any scoring/scratches on the wall. If nothing is there **** i'd say **** the whole thing and save the money.
dan, when can i come down and check my compression with your compression tool?
^^ i haz the tool! Yes I have the head gasket kit and rods and what not.... If I can find a place to do the test with the boroscope then I could do that to, but I ve been hearing a little bit of chatter that i havent noticed before on the number 4, could be the timing chain but i dont recall it being there before. I still think have a 20% leak and not knowing if its the piston or a ring is still kinda...... scarey
might get dual pass + option b and put it on the car but not sure yet. also ls4 tb and 3" intake is on. jamican me think the stock exhaust is holding me back but you know what i dun give a ****. lol
update....
Boroscoped the cylinder and there was no indication that the piston was damaged (cracking, broken) Saw that the tip of the plug melted on top of the piston head but now it looks like the detonation had damaged the valves and not caused the piston rings or ring lands to blow. There is a slight ticking/tapping noise coming from the valve train that was not there before so this is now a matter of getting a new head on bc the valve guides might be getting fucked up. Dynod it for ***** and giggles and came in at 240/209....... from a previous 262/228....... wow
where's the vid's at? also billing'ssssc/sc didn't even make 300whp? i saw charts of 310 or something but thats not corrected (10) i belive for std smoothing.
and mr. tuner x when are you going to come hook me up with a toon. lol
max ftmfw!
and the drunk dude who just chills in my basement. lol
max ftmfw!
Last edited by PerformanceClutches; May 3, 2010 at 05:52 PM. Reason: Automerged Doublepost
