Recomendation on tires????
Old 09-09-2006, 11:22 PM
CbYellowSS's Avatar
Alright im thinking about getting new tires
my stock pirellis dont seem to grip like i would like them to
can i get any recommendation for a tire???
i mainly need one for little street use and mostly racing use
Old 09-09-2006, 11:49 PM
ameaglemike's Avatar
Nitto. Period, end of discussion. The Nitto NT555 series tire is pretty much the best tire out on the market. It has the best tred pattern, is good in all weather, comes in pretty much any size you can imagine, its a softer tire (than say Toyo or BFG) so it grips a hell of a lot better, and they're very reasonable priced. If you want to do racing, there's the NT555-R tire which is a bad ass drag radial. It won't last as long as a normal tire, but it gets great traction on the strip or the street. Look at www.tires.com (Discount Tire's website) to get a good selection of sizes, prices, and other brands too if Nitto's don't float your boat. I will warn you that because they are a softer tire, you won't get like 75,000 miles out of them (with the way we drive our cars...lol), but I've put them on 3 cars of mine (a '96 Grand Prix that I turned into the ultimate sleeper car, my '71 Chevelle SS w/ a 468 c.i. big block, and my '06 Cobalt SS/SC). So I hope this helps out you and everyone else some. Any other questions, just drop me a line.
Old 09-10-2006, 12:21 AM
CbYellowSS's Avatar
wow that is convincing any contenders?
Old 09-10-2006, 12:27 AM
Matty's Avatar
For street tires the Nitto's can't be beat.
Old 09-10-2006, 12:45 AM
HackAbuse's Avatar
I like those nittos, but they only make one tire for my rim size which is
205/45/R16
Would it be safe to downsize from
205/55/R16
I know i would need to get my speedo reclaibrated, but is the extra grip worth the change in more torque and less top speed?
Old 09-10-2006, 12:51 AM
selfinfliction's Avatar
your ride will be a bit rougher and the speedo will be off, but less than 2mph @60mph so that's not a big deal.
Old 09-10-2006, 12:52 AM
general exclaim 225/40/18 less than $90~ per tire and it uses the same tread pattern as the toyo proxies
Old 09-10-2006, 12:56 AM
HackAbuse's Avatar
I could have the speedo easily reclaibrated, but from 55 to 45 sounded like a big difference in final wheel diameter
Old 09-10-2006, 01:00 AM
g5mike's Avatar
Try Bf g-force or Falkons
Old 09-10-2006, 01:01 AM
HackAbuse's Avatar
I looked it up with a wheel calc,
Stock - 24.87"
Nitto - 23.26"
Difference is ~7% in diameter
Old 09-10-2006, 09:47 AM
Stock - 24.87"
Nitto - 23.26"
good catch... i should've done that to begin with. a 45 series will throw your speedo way off, give you alot of wheel gap and make the ride rougher.
Old 09-10-2006, 10:19 AM
Matty's Avatar
Stock - 24.87"
Nitto - 23.26"
That is 4.2 MPH at 60 MPH..so it would read 56.
Plus you lose top end. 120 MPH down to 111 MPH.
Food for thought.
Old 09-10-2006, 10:24 AM
cobi's Avatar
anyone have experience with TOYO proxes?
Old 09-10-2006, 10:29 AM
p7x
p7x's Avatar
Goodyear Eagle F1 GS D3's, had thesse for 3 months and i love em. Great on dry amazing in wet conditions and theres a reason why they win almost every tire comp.
But my second choice would also be the Nitto's N555's
Old 09-10-2006, 10:31 AM
Matty's Avatar
What size and how much $$$ ?
Old 09-10-2006, 10:38 AM
p7x
p7x's Avatar
With stock rim used 225/40/18's $180/tire US. For you I'd say contact wheelswest, they are the best source for wheels in tires in Canada and located in BC. See what prices they can get ya. But for me i found buying from the US paying taxes and duty I still saved around $100
Old 09-10-2006, 10:47 AM
Matty's Avatar
You lowered? Not rubbing I would expect.
Old 09-10-2006, 10:59 AM
p7x
p7x's Avatar
sportlines no rubbing, stayed away from the 235's for that very reason.
Old 09-10-2006, 11:03 AM
Matty's Avatar
Lotsa room. Wild tread pattern. These are at the top of my -when the stockers are shot- list. Thanks
Old 09-10-2006, 11:05 AM
p7x
p7x's Avatar
np, sorry for hijackin kinda.......
Old 09-10-2006, 03:13 PM
i'm running 225/45/18's with no rubbing so his 40's more than likely wouldn't
Old 09-11-2006, 01:08 AM
CbYellowSS's Avatar
well i looked at the nittos and i want them really bad but they done have the size i was looking for
any suggestions on the size i should use for the nittos on my cobalt???
Old 09-11-2006, 06:14 AM
nitto 555
225/45/18
Old 09-11-2006, 11:36 AM
Matty's Avatar
nitto 555
225/45/18
Any wheel hop? I suspect no but I had to ask. And you are on sportlines? Correct?
Old 09-11-2006, 01:07 PM
Hey if you couldn't find the NT555's in the correct size, you may try the NT450. They're a little cheaper, but still have a bad ass tred pattern.
Quick Reply: Recomendation on tires????
