Removing Cat and HPTuners
I'm going to remove the cat today. How do I turn the 2nd O2 sensor off in HPTuners, and do I just disconnect the sensor and remove it so it doesn't have to hang around afterwards? Thanks!
there were three things if I remember... anything that says heated o2 sensor 2 bank one.
and something about low catalyst efficiency... or you can wait til you throw the codes... then those are the ones to disale... p01033 p01333 p00420 (don't remember exactly)
oh yeah, just look at the tune I sent ya... has them all disabled anyway
Last edited by 06blackg85ss; Mar 25, 2007 at 11:17 AM. Reason: Automerged Doublepost
If you follow the O2 sensor wire up twards the engine there is a clip you can undo, and remove the the sensor so its not hanging.
Just like JMAc88 mentioned, unclip the sensor and remove it.
Just to be safe, zip-tie the wire out of the way.
Use the attachments as guides to avoid the codes.
will be doing this as soon as i install my full 3" exhaust sans cat, that i built.
