Replaced plugs....still misfiring
First. Off what misfire code? The omega original p0300 check grounds, gap of plugs and if it is blinking it means u r fuking with emmisions.meaning ure cat. So very bad.. check compression check fuel injector resistance, harness coil packs ecm connection and full wire.harness....... I know.just becausei know. Oh wait every one should .......
everyone always talks about misfires on our cars, but I never had ONE, I switched so much **** around too. changed my plugs 3 times ect..
-get the code
-check plugs, electrode and gap
-vacuum, hoses, and lines
-get the code
it could also be a coil pack going out check the spring inside of the coil pack (at the end of the rubber boot) and see if its corroded personally iv never seen this on my car or another lsj but there is always that possibility that i dont see anyone else suggesting. happens all the time on fords
1-What are the odds of all the coils going bad at one time ? not that high unless ur have a ish loads of miles on ur car. So lets set this on the side for a while.
2- If its affecting all cylinders, did you check your AFR ?! do u have a wideband ? u might not be getting enough fuel , maybe ur fuel filter is clogged or ur pump is dying, try some duel system cleaner in the tank a couple of times. see if that helps, checking ur AFR will tell you if ur getting enough fuel.
3- Last thing are your coils and plugs getting anough power from the battery, when was the last time you changed your battery, believe it or not ur battery might not as good as it used to be and might be causing problems. however its only at WOT so its prolly the last thing possible.
4- Possible Bad Harness, Ground, MAP Sensor not reading right... Or PCM issues...Possible Just gotta check....
Just my 2 cents im not the most experienced guy in the world and others might have other ideas too
i see what your saying about the coils, ill run some cleaners and look at the fuel filter. How do i do that on the LSJ? and would anything of these things break the porcelain on the plugs? because that is whats happening
https://www.cobaltss.net/forums/how-...ictures-51977/
This is what happened to mine when i had to replace the engine, it looks like that and it got emptied in the middle, the piston decided to throw it out of the head, parts of the plug got stuck in the head and messed the cylinder up ! my bad cylinder was number 3 and number 4 just a little bit. And can you please take pics of ur bad plugs ! thanks
if u got a cat its prob fucked if your check engine light has been blinking. when it blinks its a catalyst damaging misfire. meaning a **** load of fuel (or oil in your case i guess) going into your cat, melting it.
lol not worried about the cat at all, i got another downpipe waiting to go on. im more worried about this cracked sleeve/broken rings or head gasket haha or whatever it is
I just got my car on the 19th of last month.. and the check engine light came on. long story short. they had my car since the 29th since then they replace.. park plugs,timing belt, fuel injectors,serpentine belt, cleaned the throttle body. and still dont know what the hell is wrong wth it. anyone hav anything in mind?
