Results of first dyno after the build.
Old Nov 30, 2010 | 08:14 AM
brutus.nova's Avatar
So with a year of the build done. Here are the results.
Upgraded
Diamond pistons 20 over stock.
Speed Pro Rings
Sleeves
ARP studs
Oil Pump Gears upgrade
Stainless steel Valves
78lb Springs
Titainum Retainers
injectors (80's)
Dual Pass intake
TVS with 2.9"
ZZP stage three h/e
SAAB stage three clutch
upgraded T/O bearing
Already had
Snow Meth kit
Eibach springs
Hurst Shifter
ZZP 3" exhaust
AEM intake
Yet to come
Smaller Meth squirters
OTTP rear sway bar
And I think thats it. Well the meth squirters were way to big for a safe tune. Basically if I had ever ran out of meth I would have gone so lean that I would have blown the motor. So the tune we did was without the water meth.
So it made 310 whp and about 267 torque. This was on a dyno that has historically ran a little low or what they say in the tuner world "true". The IAT's stayed below 120 all the way up to 7200rpm. I think that was amazing even without the meth. So thank you ZZP with your awesome H/E. Just thought people would like to know about this.
Old Nov 30, 2010 | 08:19 AM
cmatthewb101's Avatar
Nice. Just sucks, all the work that needs done to hit 300HP with a SC
But nice munbers.
Old Nov 30, 2010 | 10:10 AM
ralliartist's Avatar
Did you not port the head?
Old Nov 30, 2010 | 01:18 PM
InfraRedline's Avatar
Not bad numbers for no meth. Get it tuned on meth and you will pick up a good 15-20whp. Are you on stock header as well?
Old Nov 30, 2010 | 02:30 PM
Bluelightning's Avatar
Got Bewst?
Read the top of his "already had" list. Hes running meth.
But nice munbers.
All that work is mostly just a built motor and upgrades to handle higher hp. Hes on a 2.9" pulley. Lots of room to move
Old Nov 30, 2010 | 02:35 PM
Supercharged Guy's Avatar
Those numbers seem a little low with meth, I could see you getting numbers like that w/o meth
I guess ported head will be next for you to free up some extra ponies
:Edit: I just saw that you said you didn't "run the water meth"..... correct?
Old Nov 30, 2010 | 02:50 PM
terry11's Avatar
You two need to read it better haha they tuned it without meth until they can get smaller nozzles so if he runs out the car won't go lean. So no meth on that dyno
Old Nov 30, 2010 | 02:54 PM
Got Bewst?
Oops my bad lol. Read it a little too quick
Old Nov 30, 2010 | 02:55 PM
INFE's Avatar
Go turbo
Old Nov 30, 2010 | 02:56 PM
Thats why I put :edit: on the bottom of my post, you sir need to read more lol
Old Nov 30, 2010 | 03:06 PM
mrbelvedere's Avatar
when it does run out it will still go lean becase your taking fuel away
Old Nov 30, 2010 | 04:24 PM
terry11's Avatar
haha be nice. I was just excited i found a mistake. Me being A.D.D. and all doesn't happen very often
Old Nov 30, 2010 | 04:49 PM
I know I was just giving you ****!
Old Nov 30, 2010 | 05:06 PM
383_Stroker's Avatar
Nice numbers for a no methanol set-up .. and you've got lots of room to grow with the built bottom end!
Old Nov 30, 2010 | 05:31 PM
tony2toness/sc's Avatar
dont flame for this but whats a saab clutch is a clutch from a saab ??
Old Nov 30, 2010 | 06:38 PM
terry11's Avatar
Yes sir. Unless i don't know something lol
Old Nov 30, 2010 | 06:55 PM
Sizzle06's Avatar
Is 7200rpm the highest you took it?
Old Nov 30, 2010 | 06:57 PM
I vote next mods are a 2.6 and turn on the meth!
Old Dec 15, 2010 | 06:55 AM
Next mods are either going to a twin charge set up or even smaller pulley and get those smaller nozzles so I can finally run the meth. I cant wait but I am deploying really soon so it will be a little while.
I dont remember what the after market header is that I have. It was soooo long ago. I bought it from ZZP.
No port on the head. I will take it off this winter and get it done.
I went up to 8k rpm and noticed no really big gains at that rpms so just kept the limiter at 7200.
The clutch is meant for a SAAB Race series or something. I will get the P/N from Fred. A bunch of the cars he built uses that clutch and some are upwards of 350-400 HP and launch off of it all the time.
Jan 12, 2016 12:01 AM
hacadacalopolis
Oct 28, 2015 06:09 PM
maliki778
Oct 1, 2015 07:39 PM
Sep 27, 2015 08:53 PM
soundjunky
Sep 3, 2015 01:18 PM
