Rev it up stage 1 help
Old Feb 23, 2006 | 08:24 PM
dstinsman56's Avatar
Well i got the stage one from revitup yesterday, so i installed the pulley and idler and was going to install the tuner box today after work. On the way to work today i got on it for like two seconds just to see that it was boosting the way it should and it did. After work today i installed the tunerbox and there was a white wire that wasnt in the diagram, anyway now my car doesnt go into boost at all and everything is hooked up the way it should be. pls any suggestions on what it could be?
Old Feb 23, 2006 | 08:27 PM
JAESS's Avatar
My car does exactly the same thing. Before the stage one kit from rev it up I had the 3.2 pulley and was boosting around 13.5 and when I put the stage one on I'm only seeing 12 @ most.
Joe
Old Feb 23, 2006 | 08:28 PM
my problem is im seeing 0 boost it stays in vacuum
Old Feb 23, 2006 | 08:29 PM
JAESS's Avatar
O
I would contact Ray right away
Joe
Old Feb 23, 2006 | 08:33 PM
i have no clue how to get ahold of him i called and emailed no response.
Old Feb 23, 2006 | 08:36 PM
JAESS's Avatar
Leave a message and send him a pm. Give him a little time I'm sure he will get back to you. He was just online about a 1/2 hour ago. Go to his website and get all three #'s and leave a message on all three. I emailed him the other day and he called me the next morning. Great customer sevice.
Joe
Old Feb 23, 2006 | 09:00 PM
Jmc007's Avatar
I have seen one guy with the former PSI-Fi kit that this kind of problem, I think the piggyback made the stock electrical boost gauge not fonction properly. Does your car feel like it pull strong or not ?
Old Feb 23, 2006 | 09:19 PM
ray@revitup's Avatar
once again the stock boost gauge is pcm limited. the computer will not let the gauge go pass 12 psi. as for the 0 boost, sounds like something is wron with your wiring. is the car throwing an engine power reduced?
Old Feb 23, 2006 | 09:21 PM
the white wire on the tuner box is for stages to come that does not connect to anything yet
check the vacum lines on the boost sylenoid
Old Feb 23, 2006 | 09:52 PM
Jmc007's Avatar
Here are some simple facts :
1 : The PCM simply reads the voltage given by the MAP sensor, whatever it's minus 8 or + 20 PSI in the manifold. It's limited to 5V, certainly not 12 PSI. There has been many people (including myself) who ran between 15 and 18 PSI on the totally stock electrical boost gauge. There are some video on this forum to prove it.
I am currently running 22 PSI of boost, read on the Aeroforce Interceptor gauge, which is simply plugged in into the OBD port. No electrical wires modded or tapped into.
Once again, I think there is a minor issue with the piggyback (not the piggyback itself, but the way it's wired or programmed) on the kit you sell. At least there was one minor issue on the former PSI-FI kit, like I have myself whitnessed once.
Old Feb 23, 2006 | 10:03 PM
my car is very slow right now it doesnt even spin at the top of first it definitly is reading the right psi. like i said it worked fine in the morning before i did the piggyback. im going to re look over the wires that i soldered but i am almost positive i did nothing wrong. it does have a code but it always had one cause of the k and n intake.
Old Feb 23, 2006 | 10:11 PM
hennessey833's Avatar
Hey jmc007, what kind of power are you putting out? Any problems with that small a pulley?
Old Feb 23, 2006 | 10:13 PM
working on a boost gauge fix right now, brb
Old Feb 23, 2006 | 10:15 PM
Jmc007's Avatar
Roughly 24% more WHP and 24% more WTQ than stock, untuned for now with a shitty timing and a not optimised air fuel in the midrange RPM's.
Old Feb 23, 2006 | 10:17 PM
Jmc007's Avatar
Originally Posted by y2kzman
The psi fi/ Rev it Up kit clamps the map signal at around 12 psi. It is the wire that you have to cut. The gauge is never going to go above 12 because that is the max that the piggyback will allow the pcm to see. If you must have an accurate gauge get an aftermarket one.
It just the way that they tuned the car. Map clamping is a popular way to tune srt 4's running higher than stook boost levels. It is a common practice to keep the stock computer from freaking out above stock boost levels.
It's not an issue with the kit, it is an issue with the way GM decided to operate the boost gauge off of the pcm.
Interesting, but not on the safest side ...
Old Feb 23, 2006 | 10:19 PM
looks like i have the boost gauge fix, i will post up after i go for a ride
Old Feb 23, 2006 | 10:22 PM
well looks like it works
Old Feb 23, 2006 | 10:23 PM
give me a few more hours of testing
Old Feb 23, 2006 | 10:26 PM
y2kzman's Avatar
Hope the fix works I would love have my gauge reading correctly again.
Old Feb 24, 2006 | 01:46 PM
post up some picks of the line you disconnected in order to make the gauge work right, im only reading ten psi also. ps i got the sc boosting again, there was a slight misprint on the wiring diagram but it was my fault for not noticing it. guess i was just to excited to get it hooked up.
Old Feb 24, 2006 | 01:52 PM
BoomInIt's Avatar
My stock gauge was reading 15 psi at the top of my rmp range, but now with my aeroforce gauge I see 15 psi alot sooner. The stock gauge was not accurate with the stage 1 kit and did not work for me thats why a scangauge is a must for any upgrade. It looks a hell of a lot better too!
I had similiar issues with the wiring. PCM com1 had a pink/black wire to tap into, but it was at postition 11 instead of 13. I think 13 was a grey wire but the pink/black is the one you need to tap into for power.
Old Feb 24, 2006 | 01:57 PM
when i called them they told me i should be running around 18 pounds of boost.
Old Feb 24, 2006 | 03:51 PM
BoomInIt's Avatar
I thought the 2.7" pully would be at 18psi, but the 2.85" I don't know...If you hit 18osi let me know!
DarrenGC
Dec 24, 2021 01:55 PM
HEATON
Oct 16, 2015 07:21 PM
nathan112i
Sep 30, 2015 07:12 PM
grampss
Sep 27, 2015 08:51 PM
DocSvensk
Sep 27, 2015 02:24 PM
