Rod bearings?
Old Mar 5, 2008 | 10:43 AM
thatotherguy's Avatar
Rod bearings?
where can i buy them? and valves.. because i have ticking noise on the left side of the motor and im thinking its one of those or the cam gear things thats your timing chains on.
Old Mar 5, 2008 | 10:56 AM
Blown 4-banger's Avatar
Rod bearings are going to be found at www.crateenginedepot.com I got mine there for like $15. As for valves, I have a full set of 16 valves in perfect conditions in case you might be interested, as well as a set of stock cam gears.
Old Mar 5, 2008 | 02:25 PM
i cant find the bearings on there. but how much you want for your valves?
Old Mar 5, 2008 | 02:37 PM
Acidangel_5.0's Avatar
you would know if you spun a bearrings or dropped a valve...
Old Mar 5, 2008 | 02:40 PM
Pully Police's Avatar
Take your car in and get the timing chain and drive assembly checked. There were problems with *some* the 2006 cars and there is also a TSB about it - go see your dealer as what you are describing are the textbook signs of this problem.
-P
Old Mar 5, 2008 | 03:05 PM
Area47's Avatar
Rent me! per hour
it's your timing chain tensioner.
Solaris99
28
Mar 15, 2017 01:22 PM
ineedacobaltss
Nov 7, 2015 02:25 PM
HEATON
Oct 16, 2015 07:21 PM
Stuff
Oct 1, 2015 05:47 PM
OPCrer
Sep 27, 2015 08:11 PM
