Rotor Question...
Old Jun 5, 2012 | 12:50 AM
xWKUJoBo36x's Avatar
Rotor Question...
Do I need new rotors if my steering wheel is shaking when I brake? If I brake hard it doesn't shake but if I apply some moderate pressure it does...
If yes, what are the best rotors?
Sounds like a question from a test in school
Thanks!
Old Jun 5, 2012 | 01:06 AM
Sir_Hiro's Avatar
It does sound like its your rotors that are warped..Id say stock would be best and cheapest..and dont brake so hard all the time..let them cool down between braking if you can.
Old Jun 5, 2012 | 07:02 AM
Owen S's Avatar
^Agreed. And hammering them on and coming to a complete stop and holding the pedal down won't help either. I'd personally suggest R1 Concept brakes, slotted only, not drilled.
Old Jun 5, 2012 | 07:07 AM
BoostedBeaner's Avatar
Agreed and agreed
Old Jun 5, 2012 | 11:13 AM
I don't hammer on them, my car just hit 90,000 miles so it's getting pretty old haha but thanks for the help guys
Old Jun 5, 2012 | 12:08 PM
Superbalt06's Avatar
Also make sure you torque your lug nuts and don't put them on as tight as you can. A lot of people use impact guns on them and that can cause the rotors to warp faster.
Old Jun 5, 2012 | 12:47 PM
YelCal7's Avatar
I will tell you this. The MAIN reason why brake warp most of the time is Control Arm Bushings. It did to my car shaking really bad then I decided to go OTTP and they have Spherical Control Arm Bushings. They runs about $200 dollars and they will STOP the shaking/warp brake. Trust me, it's worth it. GM put in CHEAP Control Arm Bushings cause they want YOU to slow down or making you keep coming back to them and they are robbing your money BIG time. I decided and said to myself SCREW this and get Spherical Control Arm Bushings from OTTP and noticed it's WAY better. It stop shaking brakes, make less wheel hops, NO shaking at high speed. It's dangerous if you get unexpected somebody is in your way and you have to stop really fast. You'll be out of control, that's for sure.
Old Jun 5, 2012 | 12:55 PM
TurboTechRacing's Avatar
Sounds like you have run out, or street terms, warped. EBC is a popular choice and are in stock.
Old Jun 5, 2012 | 02:26 PM
mrbelvedere's Avatar
your high control arm bushings dont cause rotors to warp
Turbo Johnny
Feb 21, 2019 09:41 AM
Jan 12, 2016 12:01 AM
DANRICKARD
Oct 1, 2015 12:08 AM
Sep 27, 2015 08:53 PM
grampss
Sep 27, 2015 08:51 PM
