rpms dropping problem??
Old Jun 16, 2009 | 01:55 PM
Sachemhockey44's Avatar
Recently ive noticed that if i rev it up to about 3k rpms or so, when the needle drops back down itll go alittle under 1k rpms then jump up a little above 1k rpms, then drop down to like 500 and like sounds like its about to stall for a second, then itll go to idle and idle fine after that...figured this wasnt normal and was wondering if anyone has an idea wat could be wrong?? thanks
Old Jun 16, 2009 | 01:58 PM
CinciSS07's Avatar
is your a/c on when it happens?
Old Jun 16, 2009 | 02:35 PM
no, i know it happens when i used to put that on but this is with nothing on .... i was htinking maybe my fuel pump was going because its been makin a little bit of a humming noise lately.
Old Jun 16, 2009 | 03:29 PM
OffLightsEdge's Avatar
I had issues like that when the alternator was starting to die on a couple of my previous cars. Nothing like that with by Cobalt yet though.
Old Jun 16, 2009 | 05:22 PM
anyone else??
Old Jun 16, 2009 | 05:24 PM
RednBlack's Avatar
I took my car in for the exact problem was told it was normal due to my cai and they would not do a reflash because the tech was very persistant it was normal. walked out a 100$ richer though
Old Jun 16, 2009 | 05:27 PM
blackbolt89's Avatar
lol what did you steal?
Old Jun 16, 2009 | 05:50 PM
RednBlack's Avatar
haha i meant by not paying for the reflash
Old Jun 16, 2009 | 06:37 PM
lol doesnt seem normal but w/e
Old Jun 16, 2009 | 06:42 PM
do you notice your lights get dim when this happens?
could be your alt?
Old Jun 17, 2009 | 01:03 AM
yea my lights get dim for a second...****
Old Jun 17, 2009 | 02:20 AM
Caligula's Avatar
Mine does this, it did it alot, then I got the stage 2, and it stopped, now its back again. Mines when the AC is on now though.
Idk whats up with it.
Old Jun 17, 2009 | 02:26 AM
YelloEye's Avatar
could be your alt?
Lights dim because they are used to running at 14.4volts (your alternator) when the motor slows down the alternator doesnt put out as much current and therefore the lights drop lower towards 12volts (your battery)
Also, mine has done this since I bought it 3 years and 80k miles ago....its normal
Old Jun 18, 2009 | 10:03 PM
ah thanks guys....relieved
Old Jun 18, 2009 | 10:11 PM
Area47's Avatar
Rent me! per hour
front 02 sensor
dirty throttle body blade.
needs tune work.
Old Jun 19, 2009 | 03:44 AM
G_Pelly's Avatar
Mine did that right before my throttle postioning sensor went out and I had to replace the throttle body
Old Jun 19, 2009 | 03:53 AM
Steven Flit's Avatar
Originally Posted by Area47
front 02 sensor
needs tune work.
Most likely the culprit
Old Jun 19, 2009 | 11:28 AM
Area47's Avatar
Rent me! per hour
not always.
RaginChopsuey
Oct 27, 2015 01:27 PM
patooyee
Oct 15, 2015 05:11 PM
Trav3480
Sep 28, 2015 02:46 PM
DocSvensk
Sep 27, 2015 02:24 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
