View Poll Results: is it safe?
yes
40.54%
no
22
59.46%
Voters: 37. You may not vote on this poll
Is This Safe?
my vote is yes but with a careful no, try and search for my thread, im currently running a 2.9 and injen with no problems, did the boost bypass and over 50xxx later no major problems, i dont punch it all the time because id lean out probly but it is possible and has greatly increased my performance over the stock trim, hope that helps
just a little warning. my car was throwing a lean condition code with just intake and cat-back exhaust and i needed a PCM update from GM. i recommend that you get all the PCM updates that GM has for our cars. Search here on the forum, i know there was a list of them somewhere.
A 3 inch pulley intake and catback on my car made me run 13.7 at redline....i'll post up the a/f ratio sheet
Stock tune, stock injectors
I made peak hp at 5500-5600 rpm .... put down 235 whp and 211 wtq....as you can see, the 3rd pull made me run into the 9's...maybe even 8's don't even know
Last edited by memphisr24; Oct 29, 2007 at 01:45 PM. Reason: Automerged Doublepost
I would say no, The stage 2 kit comes with a almsot 3.1" pulley and it runs 42.5lb/hr injectors.....i would just buy a catback exhaust and CAI, it will net you more hp anyways on a stock car and you would be running safe, why risk it?
well actually let me redo that sentance, i feel you would get more power to money spent with a smaller pulley,
I agree, with the hp/dollar ratio, but i think you are best off just to not risk running the car lean and having your injector duty cycle through the roof? Plus you will need to get a new hub for the pulley anyways, and a pulley removal tool to take off the stock pulley.
but like the rest said you will be alot safer with the complete stage kit
Dude its safe. Not the safest thing in the world but when all of us down here were trying things out before the cobalt even came out we had guys with 2.8's on stock injectors and stock everything else. I ran a 2.9" with only an intake for a long time with no problems whatsoever and as you can see from my mod list that was a LONG time ago. Theres still vids of me on streetfire.net with those mods doing camera flybys if you wanna check it out. just search my username over on streetfire.
The pulley makes less difference than the injectors and a tune. Pulley is like 12hp, injectors and tune in like 30hp. All crank of course. And after looking at those AFRs......no no no no no
if all you can afford is a $50 pully, you probably should have bought a cheaper car.
be patient and save your money and do your modding properly.
if you cant afford more than a $50 pully right now....you definately cant afford a blown engine.
Im putting a 3 on this week sometime , but with a heavily massaged tune and LT1 maf . At least do the tune , Rob had my stock pulley car flying . 3 is the lowest Id go on stocker injectors .
I think a "good" tune will make u smile more than just throwing a pulley on .
i can afford the pulley and im not broke, im just saving a little money b/c i leave for bootcamp In Jan. I was Playin on Running the S2 Pulley on Stock Tune And Injectors Til I Leave When i Came Back, and since theres no one in Alabama with hptuners, ill wait til i get to texas to have someone in the area tune for 60's.
