Safe to resleeve an LSJ?
I've got an LSJ with some pretty severe scouring in the #1 cylinder wall from a ring. My local machinist told me he's had issues resleeving ecotec's in the past, he mentioned one guy had it done and 6 months later he was getting his oil & antifreeze mixing.
Is there any truth to this? If not, what is my best bet for new sleeves...OEM or another brand? This will be about a 300 hp build. |
Contact MrBelvedere on here, he's got a lot of experience with sleeves and these blocks.
It CAN be done, but must be done right. The material around the stock sleeves isn't thick and can be damaged pretty easily if the proper tools aren't used and procedures followed. |
I have the tooling to resleeve ecotecs
Originally Posted by mrbelvedere
(Post 7596899)
darton is overpriced I have a sleeve that is just as strong and cheaper
(Post 7597015)
wet
Can you send pricing and info please.
Originally Posted by jonah
(Post 7597560)
cavitation?
Wet sleeves have cavitation problems when the piston fires the coolant on the other side collapses with air bubbles ( cavitation) and can cause damage to the sleeve over time I know this happens with all sleeves just wondering if your sleeves have had problems with this
If that was the case all engines sleeved or not would have that problem
They have grooves machined into them to agitate the water to keep them cool |
(Post 7598106)
If that was the case all engines sleeved or not would have that problem They have grooves machined into them to agitate the water to keep them cool
What dose darton have that these don't I know darton is super expensive but why are your cheaper
1 Attachment(s)
Attachment 12156
mine are made of the same material and you don't have to butcher the block nearly as much as a darton to install I have a vendor that worked with me to set a price that people can afford |
How can I purchase the sleeves and what metal do you use for pegging
you can use what ever you want to peg if you want the sleeves pm me
(Post 7598366)
Is this reasonable at all?
Go for it
I would NOT fill the block, totally not necessary on these blocks, you just need good sleeves or a newer block casting. Both of which are available and much more proven than a potentially disastrous DIY block filler.
So there's no aluminum block guard ( girdle) that is usable with the LSJ
Yeah but only if you buy a zzp block
No, ZZP used to sell a block with essentially a welded in block guard, still had issues with the stock sleeves and other problems. Use the thicker Mr. B sleeves, or go with a newer closed deck block.
PROPERLY TUNED, a stock LSJ can make 500whp, so the sleeves/block aren't bad. Most failures are tuning/setup issues. |
