SC Pulleys
SC Pulleys
I am looking to upgrade my 2006 Cobalt SS SC and I am looking for suggestions on what size supercharger pulley would get the best performance while keeping the car as my daily driver. Any suggestions?
I was down in West Chester a month or so ago and saw a black ss/sc, what color is yours? Ever see a silver ss/sc down that way?
generally, a 2.7" pulley with 60lb/hr injectors is considered safe and reliable.
i use a 2.9" pulley with 42lb/hr injectors.. and i was running high 13's. since then i've gotten alot of bolt-ons, and have gotten down to low 13's on stock tires.
it all depends on how fast you are looking to go.
if you want 12's.. i suggest you look into the twinscrew supercharger swap, or the hahn turbo system.
you can run a 2.8 with 42's IF you know what you're doing. most people on here don't have a clue when you get technical enough to explain the "why and how" so it's safer to say no.
example: you didnt explain it
please explain, bc at 6800 my injectors were maxed on a 2.9 and that is at a a/f 11.5. They only thing i could think on a 2.8 would be shifting at 6500 before they go static
I have the 2.8" pulley, 42# injectors, and a custome tune and I dont knock nor has my engine blown up. A lot of us guys in AZ are running the same setup and have never blown anything in our engines. Its the 60# guys that blown there engines up.
I saw 2.8" and 42# and custome tune.
this way, you still get the low end torque of the smaller pulley, but you drop of the pressure up top, and maintain safe a/f ratios.
there is a trick you can do with them. it's called water injection.
thats the easy way of doing it. my duty cycle with the 42/2.8 deal hovers around 85-88% what people are stuck on is duty cycle. it is a calculation. not an exact. what is exact is the Msec. 20.0 msec is static.
i have tuned a 2.85 car, where the duty cycle was maxed at 89%. then a 2.9 car that was starting at 110%. keep in mind, this is a calculation. which is not correct for 07 cars anyways, which is what i tune 99% of the time.
at 6500 on the stock gm tune, the injectors went static with the 2.8. how do i know this? wideband showed this cute little spike. it was running a solid 11.2 all the way up. till this point, then it just sky rocketed to 12.5.
with the water injection, i was able to pull enough fuel out of the car to keep the injectors in check. it runs 11.3 from 2k all the way to 7200. no dips, spikes or anything stupid in the middle. we can't give all of our secrets away, so i won't go into detail about this. knowing this little bit of info, in short, it can be done with supporting mods. if you're not wanting to do water injection. get 60's.
Tunes is going to be required if you want to do it right. Thats what I did when I went from 3" to 2.8" You dont need anything else it will bolt up to the GM hub (if that what you got) and the belt will fit.
