Second o2 too short
did it come with an extension? my zzp came with one, and i couldn't re-connect the sensors in the stock position, i had to rig something up with zip ties and i wrapped up the slack in the heatshield.
i had that proble also. just follow the wire back towards you engine, and you are gunna need to grab more wire from up tere. i think it was a clip or something that you can disconnect to get more slack.
i just remember getting aggrivated(sp) at it, and being alittle aggressive with it. there isnt much slack, but there should be enough. see if you can follow the line up further for more clips. also, when screwing the o2 back in, you will need to twist the wire around the sensor first so that way when you are screwing it in, whe wire wont get shorter as you turn.
i already screwed the o2 back in
i disconnected it then screwed it back in but i can reconnect it cause its too short
even with the clip not attached to anything
ill go look for more clips to disconnect
Cptnslo
Sep 24, 2015 09:32 AM
SS_2009_TC
Sep 11, 2015 05:41 PM
shawnsseries
Sep 10, 2015 08:29 PM
