Security Learn Procedure
Old Jul 30, 2007 | 02:10 PM
victory_red_SS's Avatar
LSX RWD S/C conversion
There has been several people needing to know how to do the security learn procedure while working on their projects.
I haven't seen this posted or sticked to date. This seems like something that would come in very handy, so here goes.
This straight from the Service Manual and perhaps this should be put somewhere everyone can see it.
There are 2 ways to do this. One is a 10 minute option that requires a Tech 2 and a techline terminal. Lets skip to the second way.
Conditions
Use this procedure after replacing:
- Passlock Sensor
- BCM
- PCM
30-minute Learn Procedure.
1. Turn ON the ignition, with the engine OFF
2. Attempt to start the engine, release the key to ON. The vehicle will not start.
3. Observe the SECURITY telltale. After approximately 10 minutes the telltale will turn OFF.
4. Turn OFF the ignition, and wait 5 seconds.
5. Repeat steps 1-4 two more times for a total of 3 cycles/30 minutes. The vehicle is now ready to relearn the Passlock Sensor Data Code and/or passwords on the next ignition switch transition from OFF to CRANK.
IMPORTANT: The vehicle learns the Passlock Sensor Data Code and/or passwords on the next ignition switch transition from OFF to CRANK. You must turn the ignition OFF before attempting to start the vehicle.
6. Start the engine. The vehicle has now learned the Passlock Sensor Data Code and/or password.
7. With a scan tool, clear any DTCs if needed. History DTCs will self clear after 100 ignition cycles.
Last edited by victory_red_SS; Jul 30, 2007 at 04:24 PM. Reason: "for all the know it all's"
Old Jul 30, 2007 | 02:37 PM
bc3tech's Avatar
Question
totally do NOT follow there....
Old Jul 30, 2007 | 02:43 PM
OrngBalt's Avatar
Not even sure what it is you are trying to accomplish?
Old Jul 30, 2007 | 02:46 PM
ItalianJoe1's Avatar
This is how you reprogram the chip in the key if you don't have a tech 2. Is that all a security (CASE) relearn is? I thought it had something more to it than that.
Old Jul 30, 2007 | 02:50 PM
johnkb8's Avatar
tagged
Old Jul 30, 2007 | 03:14 PM
bc3tech's Avatar
security relearn is not a CASE relearn. two completely different things. and TMK there is no chip in the key. this is the Passlock feature which is activated when pushing the lock button twice and your horn chirps. it can be set off by simply opening your car door w/ the key instead of FOB after turning on passlock.
Old Jul 30, 2007 | 04:21 PM
For those who "know it all" or just those who want to learn, this is the way to reset your Theft Deterent System Components.
*see updated first post*
Old Jul 30, 2007 | 04:24 PM
bc3tech's Avatar
when/why would this need to be done? (curious)
Old Jul 30, 2007 | 04:26 PM
Old Jul 31, 2007 | 11:46 AM
bc3tech's Avatar
rock on.
Old Jul 31, 2007 | 02:07 PM
Passlock is a chip in the key, what you are talking about is the regular alarm. Passlock is a transponder in the ignition switch that reads the key, and the signals must match what is stored in the BCM in order to start the car. If you look at our keys, you see a small '+' in a circle by the black part of the key, that indicates Passlock. Corvettes and some other GM cars don't have that, but most do. This process is just to relearn the keys if you were to lose both of them or something. You have to allow the computer to learn the new frequency or nothing will happen.
RaginChopsuey
Oct 27, 2015 01:27 PM
satisfied
Oct 19, 2015 12:35 AM
Extreme Dimensions
Sep 24, 2015 07:51 PM
Superslowbaltt
Sep 22, 2015 10:24 AM
Superslowbaltt
Sep 21, 2015 07:50 PM
