Shift Light Point
Shift Light Point
I have a 2006 SC, and three interceptor gauges. Question is I want to set one of them up as a shift light and I'm new to driving manual, so what would be the best RPM to use?
Plus, shifting between 6500-7000 will drop you right into the peak torque band.
I put mine at 6500. Generally speaking, between the lag on the tachometer and your reaction time you'll probably go 200-300 RPM above it before you get off the gas and get the clutch down. I just rounded to the nearest 500 because I don't ever want to hit the rev limiter.
im pritty sher stock redline is 6500 so it all depends on what u think ur reaction time is..lol..but i would put it like 6200-6300.. but i mean its all up to u and how u drive...
BTW, you keep saying you're new to manual, do you mean drag racing or just driving one in general? You probably shouldn't worry about rev limiter shifting right away if you aren't used to a manual.
If you're talking about everyday driving, usually 3k in first then 2500 every gear thereafter. I go off speed more than RPMs for daily driving though (you'll understand what I mean when you go around a corner and need to downshift)
