Sky Turbo Fit????
Old Oct 13, 2007 | 03:12 AM
ikeryder13's Avatar
Sky Turbo Fit????
Will a saturn sky turbo kit fit our 2.0 ecotecs?
Old Oct 13, 2007 | 03:13 AM
splitimage's Avatar
its a different engine, but fairly simular, the turbo isnt that big, so "Fitment" shouldnt be an issue.
Old Oct 13, 2007 | 09:06 AM
Johnny B's Avatar
^^^i think the sky motor is the same as ours... the turbo swap is hard to fit bc its RWD.
Old Oct 13, 2007 | 10:19 AM
afireinside7710's Avatar
it has the same displacement, however its built differently and has VVT
Old Oct 13, 2007 | 10:20 AM
articzap's Avatar
You can probably make the manifold and the turbo fit?
Old Oct 13, 2007 | 10:24 AM
blackngold20's Avatar
yeah the sky motor is direct injection
Old Oct 13, 2007 | 11:57 AM
ikeryder13's Avatar
So what else would need to be done then to fit it?
Old Oct 13, 2007 | 11:59 AM
D4u2s0t's Avatar
are you buying it from someone? or planning on buying it? there are turbo kits out that you can use right now, why specifically the one off the sky?
Old Oct 13, 2007 | 12:17 PM
NJHK's Avatar
Wow @ some of the responses...
The manifold would fit, yes.
The turbocharger can fit on top of it, yes.
What people are forgetting is the position of the engines and the space underneath.
This is a graph of what the LNF engine and setup look like:
Their engine bay is much wider and the location of things are much different.
Because your engine itself is positioned differently, there is no way you could use the charge piping. Whether you could use the intercooler itself is questionable.
Another reason you couldn't use the cold side of the charge pipe is the position of the throttle body because it points down, yours points up.
So to sum it up, everything would basically need to be custom made except for the manifold and turbocharger if you really wanted to use them but I personally think if you're going to do a aftermarket setup, why sell yourself short with stock car parts when aftermarket can go much farther and be even more efficient.
Also note that the exhaust manifold is a cast iron manifold, so that is kind of a plus.
Old Oct 13, 2007 | 12:20 PM
JRelly's Avatar
you read my mind
Old Oct 13, 2007 | 12:24 PM
NJHK's Avatar
Originally Posted by JRelly
you read my mind
I have Sylvia Brown on speed dial.
Old Oct 13, 2007 | 01:42 PM
Johnny B's Avatar
^^^thats what i was trying to say too.
Old Oct 13, 2007 | 02:31 PM
Doc's Avatar
Doc
I think if you had that intake manifold it could work. The position of the throtle body is changed with it and we have a lot of room without the supercharger and intake manifold on. Custom piping and using a FMIC would work, it'd be a lot of work though.
Old Oct 13, 2007 | 03:19 PM
that means you can do the same swapp on my car right Frank? j/k
Old Oct 13, 2007 | 03:21 PM
Doc's Avatar
Doc
lets do it
Old Oct 13, 2007 | 03:22 PM
lets do it
yeah right I'm content with my 250whp right now under warranty
Old Oct 14, 2007 | 12:32 AM
ikeryder13's Avatar
So not good to do then?
Old Oct 14, 2007 | 12:33 AM
Doc's Avatar
Doc
it'll fit, you'll just have to do some fabbing..wait for the cobalts that'll be turbo'd and use those parts
Old Oct 14, 2007 | 12:36 AM
NJHK's Avatar
Read my post.
Old Oct 14, 2007 | 12:38 AM
Doc's Avatar
Doc
why is a cast manifold better..?
Old Oct 14, 2007 | 12:41 AM
NJHK's Avatar
I wasn't saying it was better, I was just saying that it's a cast manifold as in it should be decently strong and withstand cracking for a good longevity.
Old Oct 14, 2007 | 12:49 AM
Doc's Avatar
Doc
ok, that makes sense..
Old Oct 14, 2007 | 12:57 AM
NJHK's Avatar
Si Senior
elecblue06's Avatar
thank you adam for stealing my words.. .the responses that were given were starting to **** me off since they were pretty much all wrong.. i mean hell the saab 9-3 manifolds work... so the lnf exhaust manifold and turbo will work...
Old Oct 14, 2007 | 12:59 AM
Doc's Avatar
Doc
the orientation might be the issue....in theory it should work
meaning how far it goes beyond the engine
