slave cylinder questions
Old Jun 21, 2013 | 10:29 AM
PyroMechanic's Avatar
Needed to buy new bolts for my slave cylinder, one was stripped, anyways, Im using another hex bolt with similar length, does this matter?
And my big question, what is the torque needed for these 3 bolts? I cant find it anywhere.
Old Jun 21, 2013 | 11:18 AM
mrbelvedere's Avatar
if you order new bolts from crate engine depot 1877 441 5150 they should come with Loctite on them as for the torque spec it is not much but C.E.D should be able to give you the spec
Old Jun 22, 2013 | 04:53 PM
Future reference for anyone that sees this, the slave cylinder bolts need to be torqued to 89 inch lbs, which converts to 7.416 ft lbs.
brandon04
Oct 21, 2015 07:04 AM
Extremespeed
Sep 29, 2015 04:34 AM
Iceberg
Sep 28, 2015 01:31 PM
Sep 28, 2015 12:51 PM
SlowSaturn
Sep 28, 2015 11:03 AM
