Smaller Pulleys question
I don't think you would need a larger tensioner for a 2.5, pretty sure there is really not that big of a difference between the 2, but who want's to overspin their blower?
it says on zzps site they run down to a 2.7 without machining
so i thought it would need to be machined for a 2.6
ZZPerformance pulleys do not require snout machining. By developing Ecotech specific pulleys we run all the way down to 2.7" w/o snout machining.
with a 2.6 you are going to generate a **** load of heat, you dont have to but be prepared for high IAT after 1 pull- install meth you can get away without cooling mods. The cooler the better. With an extra HE it will help and you have that.
