So I want a Downpipe/Header combo.
I'm thinking about buying something for my car and decided to do research on these. My questions were:
What is a good company to buy from?
If I'm hooking it up to a stock exhaust, should I be good to go?
Do I need a tune after?
I'm going to be searching these threads to see if I can find my answer(s).
Cool thanks.
I don't like to be raspy.
You think if the OTTP one's are good?
http://www.ottperformance.com/store/...Pipe-27p49.htm
It comes with a highflow cat.
stock is 2.5. but the flange itself is 2.25. the one on mine doesnt have a flange on the exit. i just band clamp it. all you would have to do is cut off the 2.25 part of yours. put on a 2.5 connector, and band clamp it
Do you have any clips of it with your STOCK exhaust?
newp sure dont. it will only sound "raspy" because the stock muffler is so efficient at cancelling out sound. if its too loud, just put a cat in. im telling you man, this **** is nice. i can have the people that heard it with a cat in california give their opinions if need be
tell you what. for a little bit more ill even send you a stock DP already made to fit with this header AND a stock catback.
Listen to what they sound like in the rpm's.
http://www.youtube.com/watch?v=Ii3vJ7jullU
i have a nice one for $375 shipped. ZZP H/DP with every option (1.75" primaries, stainless steel flex section, stainless 2.5" DP with magnaflow cat (or stainless 3" catless DP, i have both), ceramic coated primaries, bolt on exit, extra o2 bung for a wideband, and sexy deep sounds)
